![]() | Home > Technical (L322) > Heated Front Screen - How effective? |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
How effective is the heated front screen (HFS)?
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
+1 Mine had a band about 4" wide right in the centre of the drivers FOV so they swapped the screen under warranty and it's now perfect and will melt ice reasonably quickly.
NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156 ![]() ![]() ![]() |
As above, the few times i have used mine it seems to clear a misted screen within a minute or two. |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
very effective for mist on the inside, ice and snow on the outside... |
volores Member Since: 04 Nov 2011 Location: Melton Mowbray Posts: 55 ![]() ![]() |
Hi - sorry to hijack the thread op but I have same concern with mine - it does clear but not that quick and it is vertical bands - is this normal or should it not be in bands? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Never have any mist as Air Con is always on |
Just remember - A/C only works above 4 degrees ext. temp. |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Only one side on mine works. I'm told it may be a fuse. Are there two fuses then? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
AC does work below 4 degrees, you just won't notice any cooling effect. The act of the AC at this temp range is to remove moisture from the air coming into the cabin which helps demist the screens etc |
Noddy,
How effective is the heated front screen?
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
used mine for the first time this winter today
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
Just remember to not use your wiper blades until clear guys!
