Home > Technical (L322) > Heated Front Screen - How effective?
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
How effective is the heated front screen (HFS)?
Not been cold enough for frost here yet, but on a couple of instances where we have had the screen misting up before the engine has had a chance to warm through have switched the HFS on but not sure if it has done anything. Neither side really (and no "bands") seemed to clear at all.
Now this means, to me, it is either completely broken, or just not very effective.
Have done some rudimentary trouble shooting:
Relay clicks when switch is pressed, both screen elements have conductivity, relay has a permanent live feed etc etc.
Starting to believe that maybe it is just a little less effective than I was expecting (and not as good as the P38a version I had before.
Comments?
David
Post #94389 25th Nov 2011 2:13pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Mine clears (in vertical bands) a misted up screen within a minute or so (using the Prog button to get full screen ventilation plus front & rear heated screens) and it has been fast with frost & snow at low temperatures.
Post #94393 25th Nov 2011 2:40pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
+1 Mine had a band about 4" wide right in the centre of the drivers FOV so they swapped the screen under warranty and it's now perfect and will melt ice reasonably quickly.
Demist is very quick especially when aided by the Max aircon button.
Post #94395 25th Nov 2011 2:51pm
NKSC
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
As above, the few times i have used mine it seems to clear a misted screen within a minute or two.
Post #94396 25th Nov 2011 2:53pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
very effective for mist on the inside, ice and snow on the outside...
Post #94409 25th Nov 2011 4:09pm
volores
2005 Range Rover Vogue 4.4 V8 Bonatti Grey
Hi - sorry to hijack the thread op but I have same concern with mine - it does clear but not that quick and it is vertical bands - is this normal or should it not be in bands?
Post #94625 26th Nov 2011 6:08pm
Never have any mist as Air Con is always on Smile Seriously, use the air con to remove condensation from the car, you won't get anything on the insides in the morning.
Had first frost on Thursday this week (only a light one) so got a chance to test my new screen that was fitted back in the summer. I had a couple of bands one dead centre the other in front of the driver but it cleared all the frost pdq with some help from the wipers .
Post #94638 26th Nov 2011 8:13pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Just remember - A/C only works above 4 degrees ext. temp.
Post #94713 27th Nov 2011 12:13pm
Andy
Only one side on mine works. I'm told it may be a fuse. Are there two fuses then? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #94770 27th Nov 2011 7:58pm
simon1233
AC does work below 4 degrees, you just won't notice any cooling effect. The act of the AC at this temp range is to remove moisture from the air coming into the cabin which helps demist the screens etc
Post #94795 27th Nov 2011 9:18pm
Thumbs Up @simon1233 .
Post #94807 27th Nov 2011 10:36pm
rads
Noddy,
From what I have found so far, there are not 2 fuses for the actual elements.
Actually, I don't think there are any actual fuses for the elements. There is a fuse (34) for the relay, and a fuse (53) for the ignition switch which is in the circuit, but the actual elements are protected by a single 80Amp fusible link.
If only half of your screen is working, it may be the element has gone, or the screen is unplugged on that side.
David
Post #94853 28th Nov 2011 11:11am
rads
How effective is the heated front screen?
Answer, Very, when working.
Changed the relay last night, and this morning was delighted to find a bit of condensation and a tiny bit of frost on the screen which proceeded to clear almost instantly.
Funny thing was, the old relay seemed to check out - clicked when switched on and when I applied 12v across the two coil terminals, the switch terminals did go from O/C to closed.
Only thing I can think of is maybe the relay switch terminals were failing, high resistance under high current.
Thanks for all the input.
David
Post #95693 2nd Dec 2011 9:31am
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
used mine for the first time this winter today
cleared it in under a minute and we had quite a thick frost.
beats getting the ice scraper out Thumbs Up FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #95695 2nd Dec 2011 9:35am
Just remember to not use your wiper blades until clear guys!
Next time there is ice on the screen rub your knuckles up and down the windscreen and see what ice will do to your skin, then imagine how quickly it wears out your wiper blades!
Not much better in the summer with insects!
Craig Thumbs Up
Post #95698 2nd Dec 2011 10:15am
