![]() | Home > Technical (L322) > RR 05 suspension |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
NSF Suspension Air bag leaking or knackered ride height sensor most likely - if other corners are raising ok then compressor should be ok?...
blench99 Member Since: 18 Nov 2011 Location: northumberland Posts: 24 ![]() ![]() ![]() |
no air leaks, had a sensor on but still not going up. |
Maybe Air Valves Unit blocked / faulty?
Was the new sensor re-calibrated? |
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 226 ![]() ![]() ![]() |
Sounds like you need a new shock - I had the same problem in my Jaguar |
i went to get suspension calibrated and guy said it was'nt geeting signal, so i've put old unit back on and still the same. |
If it isn't getting a signal it could be a poor connection, broken wire or you might need to find someone who knows what they are doing |
