Home > Technical (L322) > RR 05 suspension
blench99
United Kingdom 2005 Range Rover Vogue Td6 Java Black
RR 05 suspension
Please can someone help me here, my RR suspension is not rising on NSF and just coming up suspension fault on dash.i'm getting a bit sick of it now so any sensible suggestions.thanks
Post #94442 25th Nov 2011 6:16pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
NSF Suspension Air bag leaking or knackered ride height sensor most likely - if other corners are raising ok then compressor should be ok?...
...never tried it myself but there is a method of checking the airbag by spraying reasonably strong solution of soapy water on to it and seeing if bubbles appear Neutral
Post #94444 25th Nov 2011 6:20pm
blench99
no air leaks, had a sensor on but still not going up.
Post #94463 25th Nov 2011 6:38pm
delamo
Maybe Air Valves Unit blocked / faulty?
(Again, not very sure exactly what its called - just trying to offer suggestions) Wink
Post #94464 25th Nov 2011 6:43pm
Was the new sensor re-calibrated?
Post #94472 25th Nov 2011 7:00pm
EVOeng
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Sounds like you need a new shock - I had the same problem in my Jaguar
Post #94483 25th Nov 2011 7:44pm
blench99
i went to get suspension calibrated and guy said it was'nt geeting signal, so i've put old unit back on and still the same. Big Cry
Post #94492 25th Nov 2011 8:45pm
If it isn't getting a signal it could be a poor connection, broken wire or you might need to find someone who knows what they are doing
Post #94497 25th Nov 2011 9:00pm
