![]() | Home > Technical (L322) > "rear water ingress" |
| CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528
Was out for a run today - had the LHS 'hole' at the bumper bolts stuffed with kitchen roll, absolutely soaking after a return journey to Stirling.......RHS had some dampness but nothing like the LHS.
| RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380
Hi CG,
Agreed, total PITA.......my car was bone dry in there up until a couple of weeks ago - I regularly checked it so I know it didn't leak before.
Hi Mate,
| Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134
Hi SG -SC just out of Interest where are the sun roof drains so i can check ine? I to have had water in the bootwell and i have also noticed a slight dampness to the carpets on left and right side just inside the boot. |
| Matt@obsidian Member Since: 29 Oct 2011 Location: Greater Manchester Posts: 70
Ok guys sorry not updated recently. We are still bone dry after the boot seal was replaced. Being a sceptic I am still expecting it to come back but as of yet it's all good Range Rover 4.4 V8 Autobiography
hi matt,
I will check the receipt see if I can find it for you. Give me a day to dig it out Mustang Mach 1 (1971 in grabber green) Honda civic 2.2 diesel VW crafter with ICE |
Hi, Renegade2, the front drains exist on the inside of the sill just back from the A Post area, whilst the rear drains exit at the sill area ahead of the rear wheel - easy to test, just pour some water at each corner of the sunroof and watch for the water draining |
Well i have ordered a new rear seal but they are on back order with Land Rover...... |
i dont know if thats a goood sign or a bad one, good being its a common problem and thats the resolution |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
hi, sorry to come in so late on your thread but my car seems to leak after i had some paint work done, but it does it parked, you mentioned about the sunroof drains,how do you clear if they are bloked. V8 facelift Range Rover Autobiography 22" wheels.
What panels did you have painted ? You would need to get to the drain terminations and try putting some welding wire or something up the end..... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
i had the rear passenger quarter painted, at one point after some rain it was an inch deep but at other times its hammered down and its been bone dry V8 facelift Range Rover Autobiography 22" wheels.
| All times are GMT |
