![]() | Home > Technical (L322) > "rear water ingress" |
| CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528
Still no luck - That LHS corner is soaking again tonight.........just cant seem to find it.
| RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380
yeah mines is much the same. i went out today just praying it was dry..
The seal is due in around the 12th so I'll see how that goes.
| sidmini Member Since: 20 Sep 2010 Location: kent Posts: 45
Hi Guys,
Hi Simini.
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
Not sure if it's a help but when I park my car over night and it's rained, when I open the upper tailgate in the morning the water runs down the channels either side of the gas struts, down the sides of the lower tale gate and runs out under the car behind the bumper, right by where you guys have the problem. Now I don't know where the water is getting stored on mine, but I don't have any leaks (touch wood) so could be something to do with these channels on yours. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
I am unfamiliar with the leak coming from those 2 bumper holes. However I did have a water ingress into the compressor area which also needed a new compressor! Perhaps you need to check your boot rubber seals all the way round and coat with silicone spray or "einszett gummy pflege" also you might want to check and tighten down the 2 rubber bungs either side of the tailgate this might tighten the seal and stop water coming in? |
Hi Rob,
Well GC,
Hi RR8701
hi CG,
Right checked mine this morning and I had a few dribbles. I've got a couple of photos I will post up later but think its got to me the bumper seals. The pics to me look pretty certain its them. Will post later. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Just a thought.
Hi Rob,
| All times are GMT |
