![]() | Home > Technical (L322) > ABS, HDC Inactive, Air Susp Inactive - 2004 vogue |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16343 ![]() ![]() ![]() |
How's your battery? I know it may sound funny! But have the garage flattened your battery whilst doing the job and then bought up faults by either trying to start it without enough charge or worse still jump starting your car!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35702 ![]() ![]() |
and if it is the battery and i concur with craig that it probably is, a good place to get a replacement is eurocarparts [110amp 920cca varta/bosch 020] and member t24res has just put up a discount code for 15% off [BATTERY15] ... - .- -.
the_engineer Member Since: 25 Aug 2011 Location: alexandria Posts: 42 ![]() ![]() ![]() |
the battery was flattened. The car was off the road for about a week and i do believe it was jumped. Sorry for being naive but why the full lock of the wheel either way when jumping.
i had the same thing happen to me when my window tint man kept on running the windows up and down when he was applying the tints, dead battery and it was jumped normally but then all the lights happened..
When you first start the car after a battery disconnection you need to "lock to lock" the steering wheel as it lets the variable power steering know where the front wheels are and turns all the warning lights off on the dash ABS, TRACTION, AIR SUSP etc etc...
never EVER EVER! Got that, good to know! Jump leads are going in the bin lol |
Sorry, but I have jumpstarted my previous ones 10,15 20? times. Never had an issue. Jump started others from mine, never had an issue... The electrical circuits in the RR have to be able to cope with voltages ranging from 10V to 15V+ and varying ampages. If you have a flat battery this acts as a massive cushion in the system too so it is near impossible to fry anything. Once when VERY tired and not thinking strait I put the jump leads on the wrong way round once, no harm done... Not that I'd recommend it of course. If the RR wasnt designed to be jumped then it wouldnt have jump terminals. ![]() |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3232 ![]() ![]() ![]() |
I had exactly this last week adn lost all power when driving along! AA man came out and it turned out to be the battery Neg Pole and cable were not tight enough leading to intermittent power supply. Now nice and tight and running puurrrfick!! |
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 ![]() ![]() ![]() |
ive had the same message and traced it to a wheel speed sensor - £20 later fixed
kb5 Member Since: 20 Jan 2010 Location: currently in The Sudan, dont ask Posts: 63 ![]() ![]() ![]() |
Check the ABS cable on the drivers side front wheel for any cuts or nicks or rub marks sometimes they rub on the inside of the tyre and this causes damage to the cable and will light your dash up. ![]() |
thats exactly what mine was - drivers side front ABS sensor cable rubbed through...unrealy the sequence of worrying lights it lit up LOL
Have to say I have jump started plenty (using the specific jump terminal) with no problems but may have been lucky I guess.... |
i think the correct way to jump the fullfat is to connect your spare battery/powerpack/charger and let it sit for a while so the fullfats battery gets some charge and the ecu's wake up gently and power up, then turn the key ... ... - .- -.
Stan, your absolutely correct my friend...
