Home > Maintenance & Mods (L322) > Cracking the nuts!
supershuttle
Cracking the nuts!
Thought the title sounded a bit Christmassy, well the content isn't Whistle
I want to change the wheels on my RR, you've mostly had a laugh at the wheels in the garden next to the primrose w.c. but I was going to fit them last weekend but couldn't get the old ones off. I bought a Metabo Air wrench - wouldn't budge the wheel nuts, have ordered a 750mm breaker bar and so hope that will do the trick. I was going to tighten back up with the air wrench as it's stated torque is more than enough and coat pretty much everything with copper grease to avoid a repeat in the future.
I'm sure i ain't the first with this problem, has anyone got any advice they might like to share. i don't want to take the car to the tyre shop as they will gun things up too tight again, might scratch the wheels and probably won't put the wheels on the right corners. Geoff
Post #97566 13th Dec 2011 8:19pm
Try tightening them instead to crack them or whack a hammer on each one to help real the metal-metal bond Smile
I never use to use a breaker bar, just a normal heavy DIY ratchet and a 4' long tent pole(wooden from a Niger) and use that. It was undefeated lol
Post #97573 13th Dec 2011 8:33pm
dont use a whizzy gun to do up the nuts, use a torque wrench set at 140 nm.. ... - .- -.
Post #97574 13th Dec 2011 8:35pm
ric355
I've never seen a wheel nut that an air wrench couldn't undo. How much air pressure are you using? Crank it up a bit maybe?
Post #97578 13th Dec 2011 8:43pm
Take the car to Kwikfit and they will loosen them for you.
Then tighten them yourself for the journey home.
Had the same problem initially on my Disco, even the "big" guys at Kwikfit had trouble. Smile
Best few pounds ever.
Post #97579 13th Dec 2011 8:45pm
Torque wrench is the safest way to tighten them up
Post #97580 13th Dec 2011 8:48pm
supershuttle
Torque wrench ordered Very Happy
Big and cheap like myself Whistle Geoff
Post #97581 13th Dec 2011 8:50pm
Just take care with the breaker bar, cheap ones tend to snap and when they do it can hurt Big Cry
Post #97582 13th Dec 2011 8:52pm
supershuttle
I'm getting more concerned with every post - in a sort of "can you feel the force" sort of way.
That is - the sort of force I'm gonna be needing to crack my nuts Twisted Evil Geoff
Post #97583 13th Dec 2011 8:58pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
get a good 1/2" drive impack socket, 24" 1/2" drive bar (not ratchet or torque wrench) and 5lb lump hammer
Pyt the socket and bar on your wheel nuts and then give the end of the bar a good hard whack with the lump hammer, nuts will release easily.
As already stated when you put the wheels back on always use a torque wrench otherwise you will end up with the problem you have now. 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #97586 13th Dec 2011 9:05pm
I recently removed a wheel from a Omega, the nuts were so tight a 4 foot scaffold pole bent trying to undo them
Post #97588 13th Dec 2011 9:07pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
If it's a new air gun then it will need a little use 1st to get it up to full impact, same if you've not used it for a while.
Post #97589 13th Dec 2011 9:17pm
You need something like this Thumbs Up
Features:
THIS IS THE LATEST NEW MAX VERSION
EVEN MORE NUT BUSTING TORQUE FOR REMOVING THOSE TIGHT BOLTS! 1054Nm. MAXIMUM TORQUE.
Silenced Tool
Approved EU Version
2 YEAR INGERSOLL RAND WARRANTY
Technical Specification:
Free Speed 9800 RPM
Working Torque 68-746 Nm 50-550 Ft Lbs
Maximum Torque 813 Nm 600 Ft Lbs
Maximum Torque ( Reverse ) 1054Nm 777 Ft Lbs
Breakaway Torque * 1486 Nm 1100 Ft lbs
Blows per min. 1250
Net Weight 1.84 Kg 4.05 Lbs
Overall Length 187 mm 7.35 in.
Average Air Consumption 142 l/min 5.0 cfm
Sound Pressure: 86.0 dBA
Sound Power 97.0 dBA
Vibration 5.3 m/s2 Tool Rating - 4 Star - Ultra Duty
IR’s latest & upgraded 1/2'' Titanium Wrench Features an Amazing 1,000 Ft-lbs of ''Nut Busting Torque''. Super Lite weight Only 3.95 Lbs.,
* This tool will loosen a nut tightened to 1486 Nm ( 1100 Ft. lbs ) in a few seconds. This is called breakaway / nutbusting torque.
Post #97597 13th Dec 2011 10:07pm
Googsy
Standard wheel brace and a long hollow steel tube "Law of the Lever " Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #97610 13th Dec 2011 11:35pm
