![]() | Home > Maintenance & Mods (L322) > Cracking the nuts! |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3957 ![]() ![]() ![]() |
Thought the title sounded a bit Christmassy, well the content isn't |
Try tightening them instead to crack them or whack a hammer on each one to help real the metal-metal bond |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
dont use a whizzy gun to do up the nuts, use a torque wrench set at 140 nm.. ... - .- -.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
Take the car to Kwikfit and they will loosen them for you.
Torque wrench is the safest way to tighten them up |
Torque wrench ordered |
Just take care with the breaker bar, cheap ones tend to snap and when they do it can hurt |
I'm getting more concerned with every post - in a sort of "can you feel the force" sort of way.
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
get a good 1/2" drive impack socket, 24" 1/2" drive bar (not ratchet or torque wrench) and 5lb lump hammer
I recently removed a wheel from a Omega, the nuts were so tight a 4 foot scaffold pole bent trying to undo them |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2075 ![]() ![]() ![]() |
If it's a new air gun then it will need a little use 1st to get it up to full impact, same if you've not used it for a while. |
You need something like this |
Standard wheel brace and a long hollow steel tube "Law of the Lever " |
