![]() | Home > Technical (L322) > My FBH is switching itself on... |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
I'll swap. Mine won't switch on. But no ideas, sorry... |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 926 ![]() ![]() |
Thanks haha sounds a plan.
Sounds like the car isn't fully going to sleep.
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 745 ![]() ![]() |
Sorry no idea why, but mine has started doing the same ![]() Hopefully someone will come up with an answer ![]() |
might sound silly but try taking the batt out of the remote.. it could be faulty and is sending the signal to switch on... its te first thing i would do.. V8 facelift Range Rover Autobiography 22" wheels.
How do you manage to switch yours off? If I go into the car when its switched itself back on, on the touch screen 'Manual Heat' is illuminated when its on and all timers are 'Off.' Really confused. |
How about swapping them over then getting "mine" fixed on "your" warranty...
is your engine upto temprature at this point and do you lock the car when you leave it? |
Yes up to temperature, FBH comes on once I've locked the car and come back about 2 minutes later to find it chucking out so much hot air! |
Have you not asked the dealer to take a look? That's what I'd be doing if mine was a 2011 |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
This is happening because:
Makes sense. What a joke. I have taken the batteries out the FBH remote and 10 minutes later it switched itself back on. No Low Battery warning though so far. |
Rambles, you are sure of this? Confirmed by whom? This would def be an error in the programming of the FBH/ATC ECU. The reason I ask is that, after several years of playing with and researching FBHs, this is the very first time I have ever read this. And even many of the technicians at main dealers don't know poop about the FBH and tend to speak out of their @&%es just to get customers off their lots. Rumors and BS fly heavy and thick on this topic. (see 'Have I gaot a FBH' in the general section).
Steve, you seem to be an expert on this unit, any idea where I could get mine repaired? Graham
