Home > Technical (L322) > "rear water ingress"
Page 7 of 11 <123 ... 678 91011>
I love it when a plan comes together! Glad it's sorted. Now to do mine. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #97599 13th Dec 2011 9:14pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #97600 13th Dec 2011 9:19pm
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
Twisted Evil Thumbs Up
I did use a hammer at one point, not to fix anything just because i was annoyed Twisted Evil
Post #97603 13th Dec 2011 9:41pm
Your hammer obviously want big enough or you wern't hitting said problem hard enough. These are typical SBE's! Thumbs Up [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #97604 13th Dec 2011 9:58pm
RR8701
Rolling with laughter
Post #97605 13th Dec 2011 10:03pm
Renegade2
Guys this could be good news as my boot well was swimming aftre the rain today, jusdt dried out what i could and then have sealed mine armatures with good old vaseline so am hopeful that this is the problem in that area. Will let you know how it goes
The other area is my rhs as water is coming in from the pillar, i took the trim off with the speaker in and the packing was soaking wet, it seems to be coming in maybe where the top tailgate is bolted on and then comes down in the box section and drips out via a join and a rubber grommet. we thought at first it was the rubber gaiters that take all the cables through the top of the tailagte but after loosing the headling it was all dry, has any one had a problem in this area?
Post #97609 13th Dec 2011 10:33pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
excellent work guys Thumbs Up glad you've got it sorted
Gone - Range Rover Supercharged 2006
Post #97613 13th Dec 2011 10:41pm
CG-SC
Ive heard of that problem as well - check your boot seal at the corners up near the hinges - the metal inside the seal can corrode and make the seal bulge - the water gets in there and tracks down the pillar - my seal is not ggod at these corners and my new one just arrived today from Dan.... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #97614 13th Dec 2011 10:43pm
Renegade2
Hi SC yes i have checked the seal and seems to be ok, the water seems to be coming from inside the metal boxsection which is what makes me think that the hinge area is the problem as these bolt through into it as there is no access to to the bolts inside any where, i wonder if there is a gasket under the hinges as well!!??? Oh well have to get the vaseline out again, car bwill be held together with it soon. My next RR i will ask LR to put a jar in the boot for free !!
Post #97619 13th Dec 2011 11:02pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Interesting - I had some leaks in the boot before I took off the armatures and replaced with towbar armatures - but as part of that work, I did add some silicone to the neaprene seal between the armature and the body as a "just in case" measure and have now not had any leaks since ...
Post #97673 14th Dec 2011 12:04pm
CG-SC
*****UPDATE*****
Well, I stripped the rear bumper off today and fitted a towbar armature - the leak was defo coming in through the rear bumper mounts.....I could see where it was coming in.
I cleaned evrything up, fitted the new gaskets and some heavy duty roof and gutter sealant around the mounting bracket, hopefully no more leaks Thumbs Up
So now i have a rear towbar armature fitted, no electrics or quick release towbar yet and hopefully a dry boot !!
Armature was £180 delivered from PF Jones Smile Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #98205 17th Dec 2011 11:32pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
I have a LR Fixed plate towbar for sale if interested Thumbs Up
Post #98207 18th Dec 2011 1:14am
CG-SC
Well some fairly heavy rain today and a quick check tonight found my boot nice and dry with no water ingress.....phewww Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #98377 19th Dec 2011 10:13pm
RR8701
Hi CG,
that is great news. howeeeverrrr did you manage to take any pics of u taking the thing off etc etc and also pics with the bumper off.... Rolling Eyes
Smile
PS. the vasoline work around seems to be working great so far for me, not a drop of rain in the boot lol.... ill prob end up stripping it off in feb/march time when i find a couple of dry days.
Post #98378 19th Dec 2011 10:22pm
CG-SC
Hi RR8701......I have to say that I failed with the pics as I did it at my mates garage and had forgotten my camera and phone......
However, here is a thread I found that shows the rear end with the bumper removed: http://www.fullfatrr.com/forum/topic6026.html
You can clearly see the holes where the water can get in if the seal is defective Big Cry
I can talk you through the job when you decide to do it....... Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #98391 19th Dec 2011 11:11pm
