Home > Technical (L322) > flat battery
Page 1 of 5 12345>
wardpg
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
flat battery
Had a problem this morning which resulted in a flat battery.
About 15 mins before we were going out, cos it was very cold, remotely set the fuel burning heater, When i went out to car noticed that heater was not on but had been on as the car was slightly warm. When i switched on ignition, low fuel warning light was on, so i guessed that heater had turned itself off due to low fuel. Tried to start car but battery was completely flat.
Tried to jump start from the wife's car but still wouldn't turn the engine over. Rang LR assist who came out within 90 minutes. He eventually managed to start car and tested all electrics and battery, all seems ok. What he did say was that the FBH was the culprit and recommended that this should not be used for more than 10 minutes. This seems a bit daft to me as the heater is fitted with a 30 minute timer. I had used the car yesterday on a 30 mile journey so battery should have been fully charged. Have to see what happens tomorrow but anybody else had this problem. Car is a 2008 TDV8.
Post #9744 20th Dec 2009 3:16pm
nbunney
I have had a flat battery twice on my TDV8, never had an issue on the TD6.
IMO I do not think the battery is up to the job, with all the extra electrics etc.
My old 4.2TD Amazon had 2 batteris the same size as the RR one and no issues.
I have now got a battery booster / starter like the ones LR Assist use.
If you get a flat battery again I could always nip over with my starter, as you are in or around Preston.
PM if you want.
Nigel
Post #9746 20th Dec 2009 3:39pm
The doc
2008 Range Rover Vogue TDV8 Java Black
I have had the FBH on all week and when I get I use heated seats etc without problem.
The FBH also stops if the voltage is to low.
In short buy a new battery mate. '09 Freelander 2 TD4 HSE Auto for the Mrs
Using the works Fiesta 1.6 TDCI Sport Van - CHROME FREE THOUGH
Searching for a nice E63 AMG or S8 V10 to replace my "wonky" TDV8
Post #9747 20th Dec 2009 3:40pm
wardpg
thanks nbunney for the offer , hopefully it will start ok in morning-will give it a good run out. According to the LR man he says the battery tests ok but if its is us after 16 months then thats not good so i will have a go our men in Brock. By the way do you use Brock? i find sales team are good but I have had quite a few problems with service team over the the last 14 years, this is the 6th new Landrover I have bought from them.
Post #9753 20th Dec 2009 7:31pm
nbunney
They said the battery was OK on mine, but still went flat again.
Yes I do use Brock, my RR is in there at the mo. Big Cry
Service is Censored , Iwill not be using them when I have had my 2nd free service from them. See my post 'Fed Up'.
Post #9756 20th Dec 2009 8:25pm
The doc
For the cost of a battery I'd change it if not for any other reason than to rule it out, if you look at breakdowns its normally down to a flat battery so if in doubt..... '09 Freelander 2 TD4 HSE Auto for the Mrs
Post #9759 20th Dec 2009 10:38pm
The doc
ILMAO
Today my battery is dead - I ran the FBH for the full 30 mins - it was very very warm inside though Thumbs Up
LR are on the way now.
FL2 started just fine Embarassed
I'm then going to go and buy a brand new, good quality battery.
I'll let you know if I have further problems. '09 Freelander 2 TD4 HSE Auto for the Mrs
Post #9937 24th Dec 2009 11:04am
Doc,
Seems to be the cold weather!
Let us know the battery type you get and costs etc. I bought a Bull Banner (or is it Banner Bull?) battery on the TD6 and it was about £75 all in. Still working perfectly too.
Yes that's right, I have 2 Range Rovers at the moment! Whistle Very Happy Discovery 4 HSE
Post #9939 24th Dec 2009 11:44am
The doc
Luckily it has just failed the LR battery test so he is fitting a new one under warranty as I type.....
Genuine LR recovery man too in a disco 3 Thumbs Up '09 Freelander 2 TD4 HSE Auto for the Mrs
Post #9940 24th Dec 2009 12:09pm
He still works for the AA though!
When my LRA guy came out he was in an 09 D3, but it was 18 months old.....apparently had sat at Dublin Docks all that time as a cancelled order unregistered. Shady....who knows what those pikies get up to! Whistle Discovery 4 HSE
Post #9947 24th Dec 2009 5:42pm
The doc
Cool, how you getting on with your tyres Whistle '09 Freelander 2 TD4 HSE Auto for the Mrs
Post #9955 24th Dec 2009 8:39pm
I'll update the thread on that one! Discovery 4 HSE
Post #9956 24th Dec 2009 9:10pm
Paul J.
Had this problem this week.
Over use of the remote heater was the culprit. Still, the pretty lights that illuminated the dashboard when trying to start the engine was very festive. Wink
Paul
Post #9987 27th Dec 2009 12:17am
robdorling
England 2006 Range Rover Vogue TDV8 Java Black
Hi Guys i have a 56 plate TDV8 and yesterday morning i ran my FBH twice and when im went out my battery was also flat , It wass fine today but i didnt run the heater !!
Post #12104 31st Jan 2010 8:11pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
get a new battery that seems to be the general advice unless you can tie down to something else, dont forget battery dont last for ever and some times do have hidden past.
i had the same problem in summer changed the battery and the HVAC relay i have had no problems ever since
its a cheaper option for you Thumbs Up 02 Range Rover HSE Zambezie silver 4.4
Post #12113 31st Jan 2010 9:09pm
Page 1 of 5 12345>
