Home > Technical (L322) > New Spark Plugs for the LPG
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
My girlfriend bought me new spark plugs for my 2004 FFRR (im still in shock as she done it all off her own back and i had never mentioned it)
She has organised e Denso Irdium Power 0.4mm plugs and yes she got 8
I just wanted to make sure that they would be pre gapped for the 4.4 v8
Does anybody have any idea??
thanks
Neil
Post #99871 31st Dec 2011 12:26am
Only a 5 minute job to check the gaps
Post #99872 31st Dec 2011 12:30am
Iridium ones are the good ones for LPG due to the higher heat tolerance Smile
not sure on the gaps for the 4.4 though but just compare to what the spec of standard ones is Smile
Post #99873 31st Dec 2011 12:31am
cliffy
Cheers guys
Ive just been on denso's website and they state they supply on a 0.9GAP, the part numbers tie up as well she got me IK20's I04's
Post #99877 31st Dec 2011 12:35am
Also found this for you cliffy Smile
http://www.bimmerfest.com/forums/showthread.php?t=100491
Post #99878 31st Dec 2011 12:37am
cliffy
Ur a star no gapping the Iridium plugs then Thumbs Up
thanks again u saved me wrecking them
Post #99879 31st Dec 2011 12:41am
Also means on your next LPG service if they want to remap it your might get a bit better performance out of it and also dont forget your decat Wink
Post #99881 31st Dec 2011 12:46am
cliffy
Thumbs Up Its going in for its check up from the LPG install so ill be getting it done
Decat sounds good to Bow down
Post #99883 31st Dec 2011 12:50am
If you can get a salvage exhaust from somewhere with a fubar cat in it and just bash the bits out into a bucket...
local scrappy will likely give you a few quid for the bits to help recoup some of the cost.
Then just bolt the decatted section in and keep the good cats to one side in the garage for a rainy day Smile
And enjoy the noise!
Post #99884 31st Dec 2011 12:56am
Dolphinboy
How much did your plugs cost? looking to change mine at some point.
Post #99888 31st Dec 2011 1:45am
