Home > Technical (L322) > New Spark Plugs for the LPG |
Only a 5 minute job to check the gaps |
31st Dec 2011 12:30am |
Iridium ones are the good ones for LPG due to the higher heat tolerance
31st Dec 2011 12:31am |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
Cheers guys
31st Dec 2011 12:35am |
Also found this for you cliffy
31st Dec 2011 12:37am |
Ur a star no gapping the Iridium plugs then thanks again u saved me wrecking them |
31st Dec 2011 12:41am |
Also means on your next LPG service if they want to remap it your might get a bit better performance out of it and also dont forget your decat |
31st Dec 2011 12:46am |
Its going in for its check up from the LPG install so ill be getting it done Decat sounds good to |
31st Dec 2011 12:50am |
If you can get a salvage exhaust from somewhere with a fubar cat in it and just bash the bits out into a bucket...
31st Dec 2011 12:56am |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3078 |
How much did your plugs cost? looking to change mine at some point. |
31st Dec 2011 1:45am |
