![]() | Home > In Car Electronics (L322) > Lost sound whilst adding the new kit..... |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Fuse 8 is listed as Radio, and does deal with the sound too. Try changing the fuse, you never know? All the juice for the stuff in the boot seems to be on that fuse?
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
You get the power plug off the lear amp by sliding the base of the plug to the right and then pulling the plug off.
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
Cheers Joe. And yes it doesn't go off.....maybe it's broke....seems to work ok. I think thats why there is an inline switch.
DSP should indicate on the main menu screen.
Done the battery for for 3 hours ysterday...nothing.....I think the fuse for it might have blown I'll try the radio fuse also thats in the radio module in the boot. apparently theres one there. all smug in my new plug!
Fuse under the power plug on the radio, 10A |
Ah yes, forgot about that one |
So I presume that's the full body section out next to it job for that fuse??? all smug in my new plug!
Yes DSP is in black so clearly the AMP is not running.......
To get to the radio tuner involves very little work.
cheers mate, in a call all day with work so maybe have a go tomorrow......playing snooker for the team tonight. all smug in my new plug!
On mine there is a fuse inside the big black socket on the top of the radio, no need to remove?
bust power pin on AMP.....clearly broken off with corrosion....not sure what to do as it's working sometimes!!!
I had a broken/corroded pin on my dsp amp.
