![]() | Home > Maintenance & Mods (L322) > Carbon Fibre Center Console |
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 ![]() ![]() ![]() |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
Do u mean wrap in carbon fibre? |
Yes it's all going to get wraped in the 3m stuff,
I was thinking of doing that as well but in a walnut to match my existing trim. Primarily the two strips either side of the gearbox tunnel and maybe the window switch pack. Its hard to find though..... Present :2008 TDV8 HSE
@ googsy-There's a place in greenogue business park in rathcoole that does wrapping..u can go up to see their work, v good IMO.. |
Walnut carbon fibre!!!
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
Why are you bothering to carbon fibre your neon screwdriver? You wont be able to see it light up?!
So that when it gets shoved up ur |
Thanks Lolo not far from me .
Yes I have seen that stuff, need to just test it actually stretches,
True about scratches but im sure the flexibilty would be fine especially if applied using a heat gun but at 5.99 a roll its bound to be worth a try. Failing that theres always Ronseals paint and grain |
Gosh that was a little harsh.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3959 ![]() ![]() ![]() |
Today I did a bit of carbon fibre wrapping, it's not a easy as they make out especially on fiddly stuff like round the dials and the vinyl doesn't stick that well to the plastic. I have done the side strips either side of the centre console and the two lower dash panels - I will refit tomorrow and maybe post some photo's - but only if it looks nice |
