Home > Technical (L322) > IIDTool: FAULT CODES - EAS/air suspension/amp/speaker faults
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Hi All,
I am getting the following codes relating to suspension fault.
5A20 Unknown
C132 Lost communication with ride level control module
Any ideas?
Also getting the following random codes.
9A56 Unknown
9D57 Unknown
9A05 Speaker 5 circuit: Which speaker location are these?
9A06 Speaker 6 circuit
Post #115582 30th Mar 2012 11:17am
SteveMFr
Site Sponsor
As general info (happy already received a PM from engineer Patrick):
Code definitions for
5A20: Pressure increases too slow when filling reservoir
This fault can appear after using the test valves and/or deflate functions of the IIDTool. It can also appear when lots of height changes are done successively. Before starting to investigate, clear the fault first and see if it comes back shortly after being cleared (drive the vehicle normally for a few days).
C132: Lost communication with ride level control module
Lost communication errors are frequent and rarely need attention. They help diagnose a system when there is a real connectivity problem (does not seem to be the case here). Again, clear and observe.
Patrick's info on the speakers:
For your speakers issue, I spent some time this morning to see what speaker is associated with what number.
The following are for the Logic 7 system.
9A05 Speaker 5 circuit: Low Range Rear Left Door
9A06 Speaker 6 circuit: Low Range Rear Right Door
The low range speakers are the one at the bottom of the doors (black grill).
The following is from our FAQ that will eventually be published on our website:
When investigating this issue (speakers not working), we found wires under the driver’s seat that were rubbing on a metal plate and shorted to ground via this plate. We also found the same issue under the passenger seat.
This link shows several pics of the damage we had http://www.gap-diagnostic.com/RR2007/WiringProblem/
9A56 = B1A56 Antenna circuit : You might have to investigate this one if you have problems with your traffic message system. Other beta testers also reported this fault but nobody gave us the cause.
9D57 = B1D57 Antenna 4 circuit : Can you tell us from which ECU (read fault>individual ECU) this message comes from?
Here is the table of corresponding code and speakers :
For the non logic 7 I compared the schematics - so it’s by deduction only. Will have to be verified someday. Of course, this is true for the amps on the L322 most system only. Range Rover i-bus, Sport and LR3 will have to be checked.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #115718 31st Mar 2012 11:10am
Stephen.125
Thanks Steve.
I should add that I got the fully detailed response from Patrick SO quickly, staggering service.
I've cleared the compressor fault and will see what happens when I go for a drive later.
Thumbs Up Thumbs Up Thumbs Up Bow down
Post #115731 31st Mar 2012 1:27pm
DMRR
I will be checking out my speaker errors very shortly too Smile
Excellent service! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #115732 31st Mar 2012 1:29pm
DiREW0LF
United States 2008 Range Rover HSE Supercharged Zermatt Silver
Wow, I don't think they put enough wiring under the seat. Laughing
Post #115778 31st Mar 2012 5:08pm
SteveMFr
Site Sponsor
That's the side with the BCM...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #115796 31st Mar 2012 6:56pm
SteveMFr
Site Sponsor
happymadison1978 wrote:
Thanks Steve.
Thumbs Up back Laughing
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #115798 31st Mar 2012 6:57pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Hi Steve
What can you tell me about these fault codes (I have emailed Patrick too but no reply as of yet):
5131 air supply
5A00 control
I keep getting the air suspension locking in normal height and these faults flag up. The control one specifically never clears. The compressor seems to be pressurising fine but the car is v v slow to rise and then the compressor overheats and cuts out. Any clues from these codes???
T
Post #126040 13th Jun 2012 8:18pm
supershuttle
On a UK car it's worth noting that the wiring nest is under the passenger seat. Probably also worth mentioning that I have the two upper speakers in the rear doors not working but the wiring under the seats was OK. Need to look at the plugs on the amp etc but not quite sure where to start Embarassed Geoff
Post #126051 13th Jun 2012 8:58pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
I constantly get 9A11 code coming up on mine - I clear it but it comes straight back, from above, it says its the front centre speaker.
The Logic 7 still sounds amazing though Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #126052 13th Jun 2012 9:06pm
SteveMFr
Site Sponsor
tomthevet wrote:
Hi Steve
5131 air supply
5A00 control
T
Hi Tom,
It sounds to me as if your compressor may be on it's last legs. I'll check more tomorrow, though.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #126074 13th Jun 2012 10:31pm
tomthevet
Cheers Steve, let me know what you find.
T
Post #126077 13th Jun 2012 10:41pm
millerj90
Steve
Great write up. I have the dreaded loss of the rear mid-range speakers ( Codes B1A01 & 2)
If I'm to investigate for chaffing of the speaker cables, which side is most likely, passenger or drivers side, on a right hand drive car?
If I've understood this post correctly, I should start my investigation on the passenger side.
Many thanks.
John
Post #130608 11th Jul 2012 10:53pm
SteveMFr
Site Sponsor
Hi John,
No, you'll need the driver's side if you have speaker probs on the same side of the vehicle (RH). Generally the electrics/electronics remain on the same side of the vehicle for both LHD and RHD - aside from the switches and controls obviously.
HTH
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #130667 12th Jul 2012 10:57am
millerj90
Steve
Many thanks I've lost both sides, so it looks like both front seats have to come out Sad
John
Post #130773 12th Jul 2012 8:53pm
