Home > Technical (L322) > solar power charger
dave.s
solar power charger
Hi all, going on a cruise in august for 2 weeks and will be leaving rr parked at docks.
Can anyone recommend a solar charger that i can buy to save the poss of a flat
battery on return. Also can this be plugged into rear power socket with panel on
rear parcel shelf.
Dave
Post #119645 30th Apr 2012 10:45am
http://www.fullfatrr.com/forum/topic3121.h...olar+panel
http://www.fullfatrr.com/forum/topic5078.h...olar+panel
Post #119646 30th Apr 2012 11:08am
dave.s
Cheers for reply, have been through search but not much about the watts. i.e is it worth
getting 1.5 watt/4/5/10 watt etc. would rather buy once properly than come off the boat in my
sailor outfit and find what i've bought does not do the job.
dave
Post #119647 30th Apr 2012 11:53am
£9.99 at maplins... http://www.maplin.co.uk/solar-powered-12v-...rger-98358 ... - .- -.
Post #119648 30th Apr 2012 11:53am
m90got
United Kingdom 2003 Range Rover HSE Td6 Alveston Red
rear parcel shelf. Current Stable:
Range Rover 2003 TD6 HSE Alveston Red, Sand Leather
Ford Focus C-Max silver 2003
V/W transporter Blue 1995
Yamaha XJR1300 Yellow 2002
Kawasaki ZX7R Green 1998
Honda CBR 600 Black 1998
Yamaha RD125LC Mk1 Red 1986
Yamaha RD125LC Mk1 Blue 1986
Post #119651 30th Apr 2012 12:02pm
dave.s
Cheers Stan, seen that one but there must be a differance in capability does the 1.5 watt do the job
always like to buy once which is why i asked for recommendations. most reviews i have read are so
differing they dont help. Seaman Stains aka the wife will not be happy if we have to wait for a jump start.
Dave
Post #119652 30th Apr 2012 12:16pm
Reformed
I have the maplin one and leave it perminately plugged in the rear boot on the inside rear window. (Windows are tinted so you can't really see it outside).
It won't charge a flat battery but if your battery is in good condition my experience is that it works and keeps the battery topped up. Since buying it last year I have never had the brief HDC inactive error flash on start up after I haven't used it for a few days. Reformed
Post #119657 30th Apr 2012 12:59pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
I have a Ring 12v 2.4w solar maintainer. It works very well indeed.
Plugs into socket in the boot. For some reason i do not leave it plugged in - probably not to sure if it will cause any damage.
Post #119661 30th Apr 2012 1:13pm
dave.s
Reformed and DavidP, thanks, thats what i wanted to know first hand experience
puts mind at rest.
Cheers Dave
Post #119667 30th Apr 2012 2:18pm
m90got
I have just ordered one as my FF often stands for a week without moving, is there a problem with them if they stand for a while ? Current Stable:
Post #119670 30th Apr 2012 3:02pm
dave.s
just picked up the maplin charger so thanks to all for your help
dave
Post #119684 30th Apr 2012 4:38pm
Flashman
Just picked up a 2.4 watt one and have popped it in the rear side tinted window. Hopefully it will help keep the engine topped up as don't always do a long run to get the battery charged up. Tom
Current Drive
Previous Drives
Post #120319 4th May 2012 6:31pm
These solar chargers are all very well but if the diode in them fails, as they can, and they are still plugged into the car they effectively act as a resistive load on the battery and as a result slowly discharge it.
Starting the car with the solar charger plugged in can have a detrimental effect on the diode.
You pays your money.....
Post #120321 4th May 2012 6:41pm
DavidP
nicedayforit - that will be the reason that i don't leave mine connected and I cannot remember who suggested that I didn't. I only connect it when i'm away for more than 3 days.
Post #120399 5th May 2012 9:18am
Vogue
I have been running a Sunsei 4 watt one in another vehicle which gets infrequent use for the last 5 years - this is a good quality make. These type of solar chargers / the Maplin type etc will not recharge a flatt battery, they will maintain a battery and overcome natural discharge / battery discharge wastage, but thats it.
Post #120450 5th May 2012 8:00pm
