Home > Maintenance & Mods (L322) > Visit to gearbox specialist this week, any questions?
Page 1 of 3 123>
As above really, im off to see (for the first time) the company that rebuilds our customers gearboxes for them to update the software and give the SC a once yearly look over (gearbox wise)
Can anyone think of any questions they would like asked?
Please don't inundate me with 10,000 questions but if its reasonable i'll ask...
Craig Thumbs Up
Post #124094 29th May 2012 9:00am
Going to basics, how often do they recommend the gearbox oil be replaced? Mileage-wise and time-wise.
And do they have any particular oil type / make recommendations for the various models? Si. <This is my name.
Post #124096 29th May 2012 9:18am
......is it possible for us to reset the 'adaptive' part of the gearbox... ... - .- -.
Post #124102 29th May 2012 9:49am
Have they come across a situation where the transfer box motor works OK (even tried this with a brand new motor), and will put the box into low range, but refuses to put the box back into high range, causing TRANS FAILSAFE error messages. Only way to get back into high range is to manually wind it back with an old motor. All wiring checks out (have tested). This on TD6 '02 with GM box.
Complicated I know, but they may know something? .
Post #124113 29th May 2012 10:36am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Re: Visit to gearbox specialist this week, any questions?
1. Is there a God?
Supplementary questions:
If there is, why does he let gearboxes fail?
If there isn't, who on earth invented the torque converter?
Post #124117 29th May 2012 11:02am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
How much wood would a woo... never mind...
Just known issues/warning signs on the 6 speed please.
Cheers
Post #124118 29th May 2012 11:04am
fisha
Ask them what size of oil cooler would be needed if the heat exchanger was removed and a cooler used instead. V8 or else ...
Post #124234 29th May 2012 8:35pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Stan,
In short the answer is yes, I know because when they reflash the gearbox software they have to do so before installing the new file. However it can be a high risk strategy, with my car, the adaptations were effectively making it work, it had learned how to work despite being badly worn. As soon as the adaptations were reset, I had to get it rebuilt! 2012 SDV8 Vogue SE
Post #124363 30th May 2012 2:49pm
..but is it possible for 'us' to do it...
i've tried the process of ignition on ,foot on accelerator etc but that didn't work for me so i was wondering if there's another user method.. ... - .- -.
Post #124365 30th May 2012 3:01pm
Simes
Ignition not on - Switch off - then back onto just the auxiliary position... Not ignition on.
The brave man would try it with the engine running Smile
Post #124371 30th May 2012 3:31pm
i know the proper procedure as described in another thread, i was just doing an 'etc,etc,etc' for it.. ... - .- -.
Post #124374 30th May 2012 4:07pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Are they going to flush the gearbox ?
Post #124401 30th May 2012 6:03pm
Well, been today and they have checked mine over and have flushed the hole gearbox system, on a machine that gets all the oil out and flushes through some form of cleaning agent. It also flushes the cooler as it acts like a second larger filter and gradually clogs with crap leading too all sorts of issues... They updated the software and checked all the ECU's for fault codes...
I asked about oil changes and they said the five speed is a crap gearbox and short of servicing it every time the engine oil is changed! There is a modification they do when rebuilding them that helps but in their opinion its crap!!!
One tip they did say was to check the condition of your oil, if it looks and smells burnt then the damage has already been caused... If it seems quits clean then change it often...
Stan, they looked at me odd when i asked about resetting your own adaptions yourself so i didn't ask twice!
Craig Thumbs Up
Post #124430 30th May 2012 8:40pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
What did they charge you for the oil change ? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #124438 30th May 2012 9:02pm
£200 for everything at a trade rate...
My oil was clean and smelt right, my car is now 7 years old so i hope it will prolong its life...
Craig Thumbs Up
Post #124442 30th May 2012 9:11pm
Page 1 of 3 123>
