Home > Maintenance & Mods (L322) > Visit to gearbox specialist this week, any questions?
Page 2 of 3 <123>
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Great news Craig. Any comment about the 6 speed?
Post #124448 30th May 2012 9:48pm
Not showing the issues the 5 speed is but! It must be serviced more so if towing alot they told me... Most that fail are towing plastic palaces around 6 months of the year was his words not mine!
Craig Thumbs Up
Post #124452 30th May 2012 10:04pm
Stephen.125
Cheers!
Post #124454 30th May 2012 10:15pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Craig Thumbs Up
Interesting, the one which failed on my car must have been the exception then, it never had a tow bar! 2012 SDV8 Vogue SE
Post #124455 30th May 2012 10:25pm
Oh here we go again!!! Banging Head
Craig Rolling Eyes
Post #124461 30th May 2012 11:41pm
bozmandb9
Funny reaction to an innocent observation? Question Sorry if I offended Craig, just stating fact based on my direct experience.
Don't be so over sensitive! Thumbs Up 2012 SDV8 Vogue SE
Post #124483 31st May 2012 10:37am
Really! Hmmm...
Shocked Shocked Shocked
Post #136721 18th Aug 2012 11:56pm
ikilla2
2003 Range Rover HSE Td6 Stornoway Grey
Craig, who is gearbox specialist?
Post #136725 19th Aug 2012 7:37am
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
im still on the fence about getting mine done im on 100k now and the gearbox seem fine
is it a case dont if it isnt broke dont try and fix it Confused
Post #136726 19th Aug 2012 7:44am
mzplcg
Seems nobody asked the most pertinent question then.
"Can you/are you going to test the gearbox oil for glycol contamination?"
This is a well documented fault with some LR radiators where the oil cooler part leaks and allows antifreeze into the transmission fluid. The LR answer under warranty is new rad, new box, new TC and new pipework,
There were also a lot of cases of this with some Mercs.
Post #136727 19th Aug 2012 7:50am
Is this on the 5 or 6 speed box please?
Craig Thumbs Up
Post #136729 19th Aug 2012 7:55am
There was/is a problem with some Mercedes and glyco contamination, from memory the main cause was Valeo radiators and coolers leaking causing cross contamination. Never heard of a FFRR having this problem though
Post #136732 19th Aug 2012 8:10am
mzplcg
Both I believe Craig. Basically, any car which has the transmission fluid cooler in the main radiator will be susceptible to this. Radiators have a finite life and when they do let go quite a lot do so between the water and oil parts. Quite a common pre-emptive thing is to fit an ali rad, or a separate gearbox oil cooler.
It wasn't so much of a problem back in the days of Dexron 2 or AQF. But some of the modern oils (ZF Lifeguard ones among them) are looking like they could be slowly attacking copper although it hasn't been proved yet. But the facts are that plenty more are failing than used to 20 years ago.
Dom.
Have personally seen 4 now.
EDIT. From memory, all were either 56 plate or 07 which would make them 6 speeds.
Post #136733 19th Aug 2012 8:19am
Correct me if im wrong but my gearbox cooler is separate to the water rad im sure...
Craig Thumbs Up
Post #136737 19th Aug 2012 8:48am
They rebuild all my customers gearboxes... Just did my TD5 pickup...
Craig Whistle
Post #136739 19th Aug 2012 9:26am
Page 2 of 3 <123>
