![]() | Home > Maintenance & Mods (L322) > Cracked windscreen |
| EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 226
I would rather have a new windscreen; but make sure it is OEM and make sure they take their time in fitting it indoors. I remember a friends car which developed more problems than it solved - some horrible wind noises are not uncommon on FFRRs either after a repair.
| Squirrel Member Since: 15 May 2012 Location: Reading Posts: 212
Ah, now there's the problem - there is no indoors here that they can use. They're one of these mobile fitters. Not sure I like the idea of extra problems caused by the windscreen, just for a little crack.
| Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912
That sound like just a bad chip you should be able to get it repaired by autoglass etc I have had a couple dine in the past with good results. Like EVO says you might just loose element in that bit. Pity you didnt see it when you bought the car and got dealer to sort it.
The dealer swears it wasn't there when they did the PDI before the car was delivered. But he drove it across to my place FOC, so if it happened on that trip it would be mean of me to take him to task over it! Especially when a repair will cost me nothing anyway. I know it didn't happen while I've been driving, because I'd have noticed. There's a vague possibility that some muppet will have lobbed a rock at it, I suppose, but I can't see why they'd have done that - it's only been parked on the drive since I got it.
| edward.barry Member Since: 26 Aug 2011 Location: Cavan Posts: 37
Hi, I concur, if its a chip, a repair sounds like the better option. I has a similar issue a few weeks back and the repair took 30 minutes and is almost invisable. 0-60 takes 5 and a half seconds...and about 17 gallons of fuel....
I think the dealer will just send it Autoglass etc I dont think its somthing they do in house but I have seen a tread on here about how many screen options there are!!
| duka Member Since: 11 Jan 2011 Location: uk Posts: 147
Auto glass vacuum repair works well, subject to crack size. It only takes 5 minutes.
Thanks guys, I feel much better now about just getting it repaired. I was just worried that a repair would stop the entire heated screen working. (Even if it might, please don't post to tell me that!!)
| jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147
I got a stone chip in mine & had the entire glass replaced.
Well, this is my quandary. There's no way to tell now for several months whether the heating elements are still working or not. But then again, I don't much want the guy to end up damaging the leather trim or the electrics either.
| TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848
Turn the elements on and wait for a min or two, then you can feel which areas of the screen are warm and which are cool. |
Oh. I never thought of that. |
Put a cup of coffee on the dash near the crack/chip and wait for it to steam up then put the screen on and it will be obvious if it works then |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882
...............or put cling film on the outside and when it shrivels up you know its working.... ... - .- -.
