Home > Technical (L322) > Fuel Inject. System error message
muffster
2002 Range Rover Vogue Td6 Java Black
Hi folks.
Afraid i'm back again with another problem.
Just started getting 'Fuel Inject. System error message; on the dash.
Car drives fine and has since gone away after using the car and switching the ignition on and off.
Iv'e tried doing a search on here and google but found nothing.
So, should i be concerned. Is this a sign of impending doom.
Anyone else had it?
Thanks.
Post #126238 14th Jun 2012 8:49pm
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
Have you had it on diagnostics to see if there is a fault code logged??
Could be a good place to start!
Post #126322 15th Jun 2012 11:34am
fuel injector problem ?...like said above , you need to get a fault code .. ... - .- -.
Post #126325 15th Jun 2012 11:51am
muffster
Not got around to it yet although that's the obvious thing to do.
I first need to find somewhere to get it done as the price for a diagnostic check can vary wildly.
Cheers.
Post #126381 15th Jun 2012 6:23pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
normally either injector or fuel pump.
Post #126393 15th Jun 2012 8:57pm
PaulB
Post #126394 15th Jun 2012 8:57pm
PaulB
Post #126395 15th Jun 2012 8:58pm
ebajema
Maybe your pumps are going, have they ever been changed. You can see on the forum several issues with the fuel pumps slowly going bad and failing. Maybe on yours the ECU detects low pressure build up and faults it. Best is to get a faultcode reading done to have a better idea. Good luck. MY 2010 5.0 SC Galway green and sand interior!!
Post #126396 15th Jun 2012 9:01pm
mightymatt
United Kingdom 2003 Range Rover Vogue Td6 Santorini Black
I had the same issue ("Fuel Injection System" message, limiting torque and engine cutting out at speed) and wanted to report the fix. The garage did an injector leak back test to check all injectors were firing as expected. Turns out that two of them were leaking so I had these replaced for £185 x 2 (exc VAT) and charged £120 for the labour to diagnose a fit. All went well for a couple of weeks and on a long run I put my foot down and the "Fuel Injection System" was thrown again.
Took the car back into the garage and they hooked it up again. Fault was much harder to find as it was intermittent. The guy was able to find it by putting his foot to the floor when on diagnostics and seeing the low pressure pump drop its pressure well below what it should be producing. So low pressure pump has been replaced now and a week in all seems to be good and acceleration is much more pokey. One thing to add, ahead of injectors being replaced my car was sluggish to start, especially in the cold. After they were replaced it started first time.
Hope this information helps.
Matt.
Post #233784 9th Jan 2014 2:30pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
I've just been through all this mate. To start it was the low pressure pump then a week or two later the lift pump in the tank packed up!!!
If you do change any pumps it's worth changing your fuel filter too.
Post #233841 9th Jan 2014 6:37pm
mightymatt
Yes it is the gift that keeps on giving hey!? Had the fuel filter done a month ago during the annual service. What reg is you Rangey? Mines a 2003.
Post #233844 9th Jan 2014 6:50pm
paul271
2002 mate. My tank needs cleaned out as there's crap in the bottom of it.
Post #233861 9th Jan 2014 8:12pm
