Home > Technical (L322) > 'Water in fuel' warning light....
Tomw2000
2011 Range Rover Vogue TDV8 Java Black
Hey - so pretty hefty rainfall around where we live today. Lots of flooding and big puddles around the lovely(!) Grantham area.
I'm at work in London....wife calls to say she was going slowly (....) through a large puddle and got a 'water in fuel' type warning message.
Car was driving normally in every way and I think when she later re-started the light had gone off and the car is driving normally. It's 4.4 TDV8.
Anyone provide any info on this warning light (yeah, I realise it might be obvious) and the sort of things that might trigger it and if there's anything to worry about?
Cheers
Tom
Post #129696 6th Jul 2012 4:59pm
The warning is for water in the fuel filter, so I would suspect it was a random short circuit that caused the light to come on when she went through the lake Whistle
Post #129700 6th Jul 2012 5:05pm
^^^^you would hope so, getting water in the fuel in a car is quite tricky nowadays, I get the problem often with my plant as the lads are not too hot at filling them from jerry cans without a bit od h2o getting in as well.
usually collects at the bottom of the fuel filter, on the plant there is a screw to bleed off the water not sure on the rr though. There is nothing that can't be fixed with a hammer😜😜
Post #129718 6th Jul 2012 5:57pm
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
Re: 'Water in fuel' warning light....
Wading depth is supposed to be 700mm, so you might want to ask Mrs Tom how deep that puddle really was Laughing Laughing Laughing Laughing
as 47p2 says, probably just a short. If you had water in the fuel system, I'm sure you would have noticed by now. The engine would not like that one bit and start to cough.
Post #129737 6th Jul 2012 7:11pm
Maybe 'your lads' are topping up Mrs Tom's FFRR Shocked Laughing Laughing
Post #129759 6th Jul 2012 9:37pm
ebajema
Maybe check for water in the filter anyway. My mother got stuck one day because the petrol station attendant didn't close the tank properly and on her car that meant rainwater going straight into the tank (petrol). My dad spent hours draining the water out (he didn't want to take the tank out so first drained it and then used a cloth to dry it). Who knows maybe something similar happened to your car as well.............. MY 2010 5.0 SC Galway green and sand interior!!
Post #129778 6th Jul 2012 10:54pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Worth mentioning the top tip if there is a little water in the fuel - pour a couple of litres of meths (methylated spirits) into the fuel tank. The meths will absorb the water and happily pass through the injectors and burn. I've done this is the past on diesel and petrol engines (useful on narrowboats) and it always seems to do the trick.
Post #130270 10th Jul 2012 3:03pm
ebajema
Simes is right, that works a treat. Also using biodiesel in larger amounts dries the fuel system out. MY 2010 5.0 SC Galway green and sand interior!!
Post #130277 10th Jul 2012 4:03pm
If a couple of litres of petrol miss fuelled in to a common rail diesel can be extremely damaging what is meths going to do ?
better to use the correct product like Fuel Set to harmlessly emulsify any water . Fitting Racor fuel/water separators might be a stage too far though. 2008 MY Supercharged
Post #130278 10th Jul 2012 4:22pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
It's wet round near me and got the same message today. Pressed 'ok to clear' and it went off. Came back a few minutes later but now gone completely. Any cause for concern do we think?
Post #149765 4th Nov 2012 10:30pm
Autobiography
Also, love how the warning message says 'see handbook' but there is nothing in the handbook which says anything about 'water in fuel.'
Post #149769 4th Nov 2012 10:35pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
If you have recently fuelled up it could also be that the filling station has got water into their tanks and you have fuelled rain water that has leaked into the station's fuel tanks................. This happened last year at our local Morrison's 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #149773 4th Nov 2012 11:15pm
Allan
Same here on my 4.4 TDV8 a few months back.
My route to work is over a moorland road that often turns into a stream for a couple of hundred yards. After I drove along / through it the water in fuel message appeared only to magically disappear.
Referred to Owner's manual as directed and couldn't find any reference to it either.
I haven't had any problems since.
Post #149784 5th Nov 2012 2:10am
ahebron
New Zealand
Please do not put Meths into your fuel tank. Any water whether mixed with meths or not running through a common rail diesel is asking for big trouble. Thats why they have a water trap and warning light so we do not run water through the motor. Most likely an electrical fault with your car.
Go and do a wee experiment.
Get a clear bottle put a bit of water in then a lot of diesel and then a bit of meths. Shake it all up let it sit and see what happens. If it reverts back to seperate layers add a bit more meths and repeat. You can keep repeating this if need be. If it all blends after a few hours sitting then you might be able to safely use it.
But I wouldn't.
Adrian VW Amarok 2014 Highline auto
Post #149927 6th Nov 2012 7:05am
Seems to be only latest 2011/12 cars....... Confused
Post #149929 6th Nov 2012 8:31am
