Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 42 of 49 <123 ... 414243 ... 474849>
Weegie
Other than that I'd go with Joe90 and consider the compressor. John
GAP iiD BT-Sold
Post #554910 22nd May 2020 6:55pm
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
i know if i read all the pages i might find my answer but i havent got the time today so im going tobe checky and ask
does the the tool also work on a discovery 2 TD5?
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #554971 23rd May 2020 9:19am
Weegie
A 30 second search on the Gap website reveals - NO for Td5. Wink
AFAIK you need Nanocom or Hawkeye for the Td5. There are others. You probably know that from the D2BC.
It took me longer to type this than to find the answer. Very Happy John
GAP iiD BT-Sold
Post #554972 23rd May 2020 9:35am
MattHughes86
Cheers for that.
i would rather ask the people that 'KNOW' then go off some websites.
that and work internet is bloody slow.
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #555341 26th May 2020 12:26pm
Weegie
Thumbs Up John
GAP iiD BT-Sold
Post #555344 26th May 2020 12:59pm
Johnniehec
Well, suspension problem is solved, replacement compressor, all now working. Still strange there was no fault coming up and less than 10k miles since pump refurb kit fitted.
Thanks , John.
Post #557003 9th Jun 2020 12:02am
Discotigger
I have noticed something strange with my IID Diagnostics since I upgraded from my old TD6 to a 4.4 TDV8. I have the 8-Speed gearbox, however whenever I plug the diagnostics in and go through the ECUs, it says I have a 6 Speed gearbox. I've had the licence changed over by Gap to the new 4.4 TDV8 and checked I've got the latest software running, so does anybody else have the same on their diagnostics tools, or is it something I need to get in touch with the Gap guys about?
Post #557071 9th Jun 2020 1:09pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Have you looked at the CCF file to see if it is set to 6 Speed? Just a thought 2011 TDV8 Vogue SE
Post #557072 9th Jun 2020 1:12pm
Discotigger
@dennij, hmmm...might pop out and have a look in a short while. Can't see though how you would be able to config a 8 Speed Ecu to read as a 6 Speed Ecu.
Post #557076 9th Jun 2020 1:26pm
i remember something like this mentioned before...i think its a bug in the software.. ... - .- -.
Post #557078 9th Jun 2020 1:30pm
Discotigger
Stan, is that a bug in the Gearbox Ecu software or the IID Tool?
I understand you can get the ECU software updated, so is that what needs to be done?
Post #557080 9th Jun 2020 1:40pm
bug in the iidtool..give pat at GAP an email to confirm.
edit...mentioned here,
https://www.fullfatrr.com/forum/topic45754...ed+iidtool ... - .- -.
Post #557082 9th Jun 2020 1:44pm
Discotigger
Not much info in the link, GGDR had said he would email Gap about the gearbox readings, but nothing further in his thread, so I've sent a query to the guys at Gap Diagnostics.
I'll post any response on here, when it arrives. Thumbs Up
Just had the reply from Pat at Gap...
'It's just a typo error and will not affect anything'
So at least the mystery is solved and nothing to worry about Thumbs Up
Post #557086 9th Jun 2020 2:13pm
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Hi
I’ve got an issue with my parking sensors which is putting a fault on and causing all of them to stop working. I’ve checked usin the IID and it says that the front right sensor is the fault.
Question is, which one is it referring to? The inner or outer front right? Also, is this the right as you look at the car or the right as you’re sitting in it?
Post #562341 22nd Jul 2020 12:25pm
D3Jon
It's normally as your sitting in the car, so front right is off-side front in the UK.
Another thing, stick your ear next to each sensor when they're on, if they're working you'll hear a clicking sound. The one that doesn't make this noise is the dud.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #566869 11th Sep 2020 5:10pm
