Home > Technical (L322) > Reduced engine performance and rear differential whine
JustinP
Hi Chaps,
Whilst driving north from the south of France today, my FF SC bonged and then displayed the dreaded 'Reduced engine performance' warning message, at which point the engine was massively down on power.
I was going up hill doing about 80mph Smile when it happened, and had 1/4 of a tank of fuel. I pulled into the next petrol station and filled the tank and all was fine again.
Is this the typical symptom for the famous SC fuel pump problem, or was it simply turning the ignition on and off that cleared the problem?
Thanks.
Justin (camping just outside Paris)
Post #133985 1st Aug 2012 7:56pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Re: Reduced engine performance warning with 1/4 tank of fuel
JustinP wrote:
.... I was going up hill doing about 80mpg ....
Wow, fantastic economy from the SC Rolling with laughter
.... Read quite a few threads regarding this issue, I'd say you experienced the fuel pump problem, either that or the supercharger aux cooling pump wired backwards can also cause this symptom.
Post #133986 1st Aug 2012 8:12pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Had that with the aux. coolant pump. All sorted under warranty. AFAIK the fuel pump stays quiet until 1/8th tank then cuts out, after a couple of restarts you'll get the low fuel pressure code.
That said when my coolant pump went south I didn't restart it so I dont know if a restart/rest clears it?
Good luck!
Post #133991 1st Aug 2012 8:29pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Given that you were in S of F and have never had that issue before, then I'd say it may be the SC electric aux pump wiring due to elevated ambient temperatures.....
I presume form your Fuelly stats that you regularly go below 1/4 tank on fuel ?
When I checked my wiring, it was as per the TSB i.e wrong which, in elevated temps would put the charge temp into a fault condition.
Hope you are having a good holiday, on a brighter note, If you were holidaying where we are then the wiring issue would be unlikely to cause an error message Big Cry Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #134003 1st Aug 2012 9:34pm
JustinP
Colin - yes, I normally run my car very low and I've never experienced this before so it may be the aux pump issue, however when the fault occurred the temp gauge was showing normal temperatures.
As my car has a just over a month of warranty remaining, I will book it into the dealers next week. Hopefully there should be a fault code to help pin point the faulty component.
Cheers all Thumbs Up
Post #134040 2nd Aug 2012 8:05am
CG-SC
At least you've still got warranty, if it the aux coolant pump, from memory it's about £120 and an easy fix.
Just one point, the temp gauge would still show normal even if the aux pump is causing the issue as its the charge / boost temp that gets too hot and brings the fault on to prevent detonation.
Whatever it is shouldn't affect the rest of your holiday - enjoy ! Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #134042 2nd Aug 2012 8:13am
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Id say fuel pump, too much of a coincidence otherwise! 2012 SDV8 Vogue SE
Post #134116 2nd Aug 2012 9:04pm
DMRR
What was the external temp? I had this on my 2006 SC and it was the wiring issue. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #134121 2nd Aug 2012 9:25pm
JustinP
The external temp was 31 C, but I drove the same route last year and it was just over 40 C without problems.
Post #134153 3rd Aug 2012 9:22am
JustinP
Hi Chaps,
I dropped the FFSC into the dealers today and they diagnosed a faulty charge pump. It will be fixed either under warranty or more likely by LR directly due to it being well known a manufacturing issue, either way its not costing me Thumbs Up
My car also developed a 'worn wheel bearing sounding whine' during the final few miles home, and this has been diagnosed as a rear differential, fingers crossed the warranty cover a replacement, as I'm waiting for confirmation that the claim has been approved.
The service desk chap advised that the LR warranty company may insist on sending an engineer to listen to the whine, to confirm its bad enough to justify a replacement. Fingers and toes firmly crossed that it is, as the FFSC now sounds like a tube train pulling out of Kings Cross Station Censored
Cheers,
Justin
Post #134661 6th Aug 2012 7:14pm
CG-SC
My thoughts confirmed, I was sure that the charge pump would be the problem Thumbs Up
And perhaps not a coincidence, the service history that came with my SC showed that a new rear diff was fitted at 59000 miles at a total cost of £1200 (500 parts / 600 labour) it was just out of warranty - I think i'd have been arguing that one on 'Good Will' as it was just out of warranty, but I reckon the previous owners were obviously not short of a few quid - they chopped mine in for a brand new 5.0 Supercharged....
Glad you've got it sussed Justin Cool Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #134664 6th Aug 2012 7:22pm
JustinP
The LR Warranty Company Assessor came out to check my rear differential today, and has agreed its bad enough to justify replacement. Thank bloody goodness, as the bill was looking like its going to be the wrong side of £1500 Shocked
Sadly the LR Select Warranty does not cover the charge coolant pump and LR have also refused to pay for its replacement. I've escalated the issue to Jaguar LR explaining that as its a well known manufacturing issue which was known about from when the car was less than a year old, and seeing as the car is LR supplied and still maintained by the dealer network then they should reconsider, and I'm now waiting to hear back Mad
Post #135395 10th Aug 2012 6:58pm
Stephen.125
Great news about the diff!
Keep plugging away about the pump- bloody cheeky Censored : known issue confirmed worldwide; no recall.
I got mine done under warranty.
Post #135466 11th Aug 2012 8:46am
JustinP
My rear diff was replaced yesterda and my SC is silent again Very Happy
Still need to sort the charge coolant pump, but as the reduced engine performance only occurred once, i don't think it too urgent.
Post #136326 16th Aug 2012 8:31pm
its a good job you got that warranty, you've had your moneys worth ... ... - .- -.
Post #136327 16th Aug 2012 8:32pm
