![]() | Home > Technical (L322) > Towing with air susp. inactive message |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
As the suspension locks when towing, and mine is currently locked in standard ride height due to the above fault, will towing be a problem?
Since towing locks it in normal hight I can't see a problem per-say . 2008 MY Supercharged
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
+1 |
650 miles towing? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Yep pity gearbox playing up now |
It's not an mot failure. I had the fault on mine when it went in for mot. The garage checked with VOSA and they said it was ok. Having said that, my mot was in March, so things could have changed since then. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 ![]() ![]() ![]() |
My suspension failure was also a Steering Angle Sensor - but this also caused the ABS light to come on, and its that that is the MOT failure... l:OolΞΞΞΞΞΞloO:l
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1517 ![]() ![]() |
No problem towing with it I've that ... Mine throws the error all the time for the pressure static message and it's stayed in normal height for months including regular towing. I just can't be otherwd resetting it sometimes so it manages fine. V8 or else ... |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
It is an MOT failure if your vehicle is fitted with Xenons.
If you have adaptive head lights they do do the dance |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
if there is a load on the rear , ie a trailer/caravan then the range in standard mode will level out , if that happens then the xenons are directing their beam in the correct place, so how can this be a mot failure...or have i got the wrong end of the stick... ... - .- -. Y. O. L. O. . |
If there is an 'air suspension inactive' message then the air suspension is not working properly, and therefore is not potentially levelling the vehicle correctly, and hence the reason for MOT failure. It is an offence to drive a vehicle with Xenons without some form of automatic levelling. This is why people that swap halogen bulbs for xenon bulbs are breaking the law on most vehicles. |
Mine don't on 2011MY axle - is something wrong with mine? |
the OP , noddy , says his does level on slopes so that's ok, isnt it.. ... - .- -.
