Home > Technical (L322) > Computer average mpg
Deasy
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
I have a 02 4.4 vogue, if I go into the OBD it give me 2 mpg figures. But both read the average mpg on the car which I can reset at diff times, so....
1) why does it give me 2 of the same readings
2) can I somehow set one as average and one as current mpg????
Cheers
Post #135228 9th Aug 2012 11:19pm
Budgie
I guess it gives you two so you can check who's the most economical driver, assuming two of you drive the car.
No idea on #2. Wink
Post #135244 10th Aug 2012 12:22am
Unless I am missing something, there are two consumption / mpg monitors available on the car, simply so you can run one for long term and one for specific trips, or what ever other reason you may have.
If both are giving the same reading, then is it that you haven't reset either for a while? Reset one of them and drive like a loony (low mpg) or a granddad (high mpg) and then you should get two different readings?
Why accessing via OBD when they are there on the dash / screen? .
Post #135249 10th Aug 2012 1:13am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I have one set to show my long term mpg over several months. - 25mpg. I use the second one to show my mpg on shorter journeys - eg 30+ mpg on motorway driving etc. it's just a handy tool once you figure out how they work. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #135252 10th Aug 2012 2:31am
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
I do similar....
Consumption 1 I use for daily drives and Consumption 2 I use between fillups...
Unfortunatly there isn't a wya to set one as current consumption...
Hidden Menu 6 (or is it 3??) is supposed to show current consumption in l/100km or something like that, but I haven't had a chance to look into that yet.!!
Post #135368 10th Aug 2012 2:41pm
Deasy
Yea I use it like that at the moment, I reset one n long journeys and just leave the other one.
Joe I ment the screen, not OBD lol
Just seems abit pointless, but oh well
Cheers guys
Post #135426 10th Aug 2012 9:54pm
Ahh... OBC (on board computer) or BM (Bord Monitor as the Germans call it!) Thumbs Up .
Post #135469 11th Aug 2012 9:21am
