![]() | Home > Technical (L322) > Gearbox slow to find a gear on roundabout entry |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Have you had the ATF fluid level checked? |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
This sounds very similar to mine when it started to fail. Sorry not tech enough to know if you have the same gearbox as me, or whether it could be a different matter.
jaybear Member Since: 31 May 2011 Location: Marseille Posts: 156 ![]() ![]() |
Common issue , known and reported for SC 's ; you need to ask your dealer to update software for gearbox . !!!!!
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
I had similar shunting issues that were intermittent and got solved with a gearbox software update and a reset of the adaptions. |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 635 ![]() ![]() ![]() |
Magic, I like the idea of a s/w update to fix it! Surprised though that s/w wouldn't work at 65k whereas it did at 60k - but definitely one to get checked/done. Will also get the ATF flushed/changed and levels checked. Interesting cross post on the linkage issue (which sounds like exactly the same symptoms as I've got) but that's TDV8 not 4.2SC unless they use the same bits - but worth checking out when its on the ramp.
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 ![]() ![]() |
The linkage is worth doing first - you can do it off the ramp in off road height. I had the same issue in a MY07 4.4 petrol so not just the TDV8. you should immediately notice the stick is a lot crisper when selecting gear. |
If this is the linkage in question....then it has now been soaked in WD40 at both ends of the cranked link on the right and on the ram shaft. Didn't feel any difference in the stick. Went for a run to our nearest roundabout (4 miles) and of course it was fine, but then it probbaly would have been anyway as it didn't start going wrong at the weekend until about half an hour into each of the journeys. But here's hoping....many thanks!
I'm impressed that you can do that! I'm no Japanese racing snake, but I didn't think excessively portly, and I had to really push to get under the car even in the highest position and the sidestep was crushing my ribs! Next time, I'll pop it on the ramp! :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2017 5.0 V8 Supercharged SVAutobigraphy Dynamic SVO Palette Grey (2021-...) 2012 5.0 V8 Supercharged Autoboigraphy Orkney Grey (2017-2021) 2007 4.2 V8 Supercharged Vogue SE Tonga Green (2012-2017) 2002 4.4 V8 Vogue Bonnatti Grey (2008-2012) |
To be honest I couldn't feel any difference in the linkage stiffness whatsoever.
I dont have sidesteps, but it was no probs for me to get under. Maybe that time at the gym is finally paying off!
Have finally had an excuse for some more longer runs - down to Cornwall at the weekend and over to Exeter today. Gear change was faultless throughout so it certainly seems that working the linkage has helped. Will still get the ATF changed and checked at next service though due in a couple of weeks. Is it likely that my specialist LR Indie will be able to update the gearbox software or is that official dealer only stuff? Mike - MPx
Bit of a thread resurrection, but thought it might be interesting to report that despite the corrections applied last year (gearbox software update, ATF checked OK, linkages cleaned/greased/oiled), the same issue came back last weekend. This time it was slightly worse as, when the car lost drive, it didn't come back. I managed to work out that I still had drive in reverse, and in Sport/Manual mode - which was handy as it avoided waiting for the RAC! I also noticed that if I moved the lever through the selections P,R,N,D then D would show on the dash for a bit but would soon disappear along with the drive to the wheels.
Please have a look at my gearbox threads. They may help you as well in finding what is going on. MY 2010 5.0 SC Galway green and sand interior!!
