Home > Technical (L322) > Approach and Departure Angles
Doe anyone know what they are for an L322 circa 06-09 MY please?
Also if they have them for the D3 as well?
Im guessing they quote such numbers in the offroad height instead of road height as well?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #141574 17th Sep 2012 3:23pm
dhallworth
For the L322:
Approach angle:
Standard Ride Height: 29 degrees
Off Road Height: 34 degrees
Breakover Angle:
Standard Height: 130 degrees
Off Road Height: 120 degrees
Departure Angle without tow hitch:
Standard Height:24.2 degrees
Off Road Height: 26.6 degrees
Departure Angle with tow hitch:
Standard Height: 15.2 degrees
Off Road Height: 17.4 degrees
Can't help with the Discovery 3 I'm afraid.
Post #141954 19th Sep 2012 2:11pm
Always wondered:
If you take on a 30 degree incline, you can get up it all right at the front (or get down it) but you are very likely to bang the rear of the car because departure angle is less. Notcied this as a problem when seeing FFRR's taking on obstacles in videos. Or am I missing something? .
Post #141956 19th Sep 2012 2:20pm
mjdronfield
From here ;
http://www.carkeys.co.uk/features/discovery-3-technical-reveal-3
Discovery 3
The turning circle is 11.6 metres, the same as a Freelander; the rack and pinion steering light and responsive; the Discovery can wade to new depths of 700mm and can be ordered with clever corner-following adaptive headlamps. Short overhangs give it a massive 37.2 degree approach angle for steep banks and a 29.6 degree departure angle. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #141962 19th Sep 2012 3:01pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Joe90 wrote:
Always wondered:
I think the larger approach angle is to allow you to back out if you find the rear is going to scrape, thus ensuring you don't rip both the front and rear bumper off?
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #141963 19th Sep 2012 3:25pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
The departure angle has always been the Range Rovers achilles heel thats why folks shorten the rear on Classics and they will probably do the same on P38's and L322's when they are more affordable for serious off-roading
And a towbar makes it worse. Mine was a blue one! Smile
Post #141966 19th Sep 2012 4:04pm
mjdronfield
Not worked this out exactly, but you can approach a 30 degree slope with the front, and OK, if its perfectly "flat" and consistent, you will have an issue when the rear comes up, due to the lesser departure angle,.......
.........but in the real world, the front wheels will only have to drop down a small amount and due to the fulcrun effect, as the car "pivots" on the rear axle, the back of the car will pivot upwards, the departure angle of the terrain is thus reduced, if you see what I mean.
Its only a real issue if you decide to reverse out of a situation.
Not sure I've explained it very well. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #141967 19th Sep 2012 4:05pm
Thank you kindly David Smile
Hopefully Bala and strata won't be too bad though the guys have said one lane has a massive step in it, hence looking for waffles Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #141976 19th Sep 2012 5:21pm
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Have you checked TOPix for the answers?
Post #142020 19th Sep 2012 9:24pm
Answers above now Smile
It will really only matter on the bits that are tight, the ones that have some space I can try at diagonal turning the wheel onto it or just breaking waffles out!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #142026 19th Sep 2012 10:17pm
