![]() | Home > Technical (L322) > Oil level ZF gearbox |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
It's fairly easy to check the gearbox level, just undo the filler plug on the side of the box.
Was the engine running or not when he did this? |
The fluid change has been done months ago, I am just not sure if they have done it properly (always an issue here). Also, I don't have anything to fill to the proper level as I can't get to the GB from the top only from underneath.
Filled from underneath using something like the pump below
I need one of those, just to make sure the level is right !! MY 2010 5.0 SC Galway green and sand interior!!
No you need one to fill the box.
Will do the check first and will have a look if I can get one of these big syringes in case I need to top up the fluid level.
Can't remember to be honest ![]() 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top 1998 90 TUL FFR Hard Top XD Wolf 1993 90 Tdi *Gone: L405 4.4 VSE, L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
The engine has to be running to allow the fluid to go through everything. If you remove the plug with the engine off you will get covered in fluid |
No worries, will make sure the engine is running and the box has gone through the gears for a bit |
Make sure it's in neutral when checking the level |
Good point, don't like being dragged through the parking garage trying to check the level |
SteveF Member Since: 02 Jul 2012 Location: North East Posts: 90 ![]() ![]() |
Are you on either VI or Ikoyi Ebajema....i would be interested in seeing thid done as i'm thinking of having a go at mine when back in the UK.
Hi Steve, I live and work on Ikoyi. MY 2010 5.0 SC Galway green and sand interior!!
