Home > Technical (L322) > Should i change gearbox oil or leave it be?...
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
Hi, my rrsc is currently at a specialist having a new oil cooler fitted. Whilst its there do you think i should gear the gearbox oil and filter changed? the car is a 2005 supercharged model done 52k and as far as im aware it has never been changed. What are peoples views on this? Is it advisable or best leave it be. Thanks
Post #149704 4th Nov 2012 2:59pm
Yes have it flushed and new filter and ATF
Post #149719 4th Nov 2012 5:16pm
marcoos_1
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Absolutely........well worthwhile.........you'd kick yourself if you don't and god forbid something went wrong.
I've just had mine done as a precaution......some further peace of mind knowing its done. And not really expensive anyway....
Post #149729 4th Nov 2012 6:54pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I agree, may as well change the oil whilst it's in.
Post #149733 4th Nov 2012 7:10pm
JPS
Cheers guys, I just wondered if there were any negative effects on changing the box oil. I'll get them to do it I think and the filter to
Post #149741 4th Nov 2012 7:40pm
I don't beleive the scaremongers who think it's unwise to change the oil. Does your car break down after an oil service? No. It lasts longer and runs better.
I had my gearbox Megaflushed, which replaces 97% of the ATF whereas the normal garage process of dropping the sump and filter only flushes 60% out, even if they do it twice. One flush removes 40% of the old oil. I DO think that if you only remove a partial percentage of the ATF and mix it then with new, you don't get the benefit, do you?
plus, the Megaflush routine was MUCH cheaper than the Dealer charge to do a oil change. Discovery 4 HSE
Post #149746 4th Nov 2012 8:00pm
JPS
Hi, I've not heard of this 'megaflush' how do they do this and how can I find out if there's someone in my area? Also is it possible to check the level of the fluid yourself? Many thanks.
Post #149752 4th Nov 2012 9:05pm
RRPhil
There’s a school of thought that, because ATF has a high detergent content, there’s a risk that the new fluid will clean out all the crud that’s come off the clutch plates, bearings, bushes, etc. over the years - that’s currently sat lodged in the various nooks and crannies in the transmission casing where it’s doing no harm - and send it through the valve block causing the transmission’s hydraulic control system to subsequently fail.
I don’t particularly subscribe to that view personally – when I had my torque converter replaced at 103k miles in my 5HP24 I had the transmission fluid & filter changed (for the first time) and have had no problems since.
Much more important is to use the correct Shell ATF M1375.4 / ZF Lifeguard Fluid 6 for your 6HP26 and a genuine factory filter, in my opinion.
Phil
Post #149756 4th Nov 2012 9:32pm
JPS
Hi Phil, thanks for the advice, the car is having the correct fluid and filter change as we speak. peace of mind i think. Thumbs Up
Post #149873 5th Nov 2012 5:03pm
Vogue
Phil, logically I agree with you.
However, having had the oil changed in the Gearbox / Torque Converter on a digger, it was running just fine before. After the oil change its totally FUBAR'ed - wish I hadn't bothered.
Would it have failed anyway? I don't honestly know, there were absolutely no symptoms prior to the change, afterwards its bloody useless, intermittent drive and top speed of 1mph.
Post #150160 7th Nov 2012 9:46pm
