Home > Technical (L322) > removal of tpms |
doug Member Since: 17 Apr 2009 Location: montrose ish Posts: 12 |
does anyone have any idea? are they designed to break on removal? |
20th Jan 2010 1:01am |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi, is the sensor not fitted via the valve hole, my brother had them on a ford he had, they are the same unit, and they were fitted through the valve and then a nut held them in place, two min job, but you need the tyre off to remove and fit. V8 facelift Range Rover Autobiography 22" wheels.
20th Jan 2010 9:27am |
hi,thanks for your reply
20th Jan 2010 8:07pm |
coko Member Since: 13 Sep 2009 Location: ... searching ... Posts: 107 |
I would have thought that it is a few minute job on the computer.
20th Jan 2010 9:03pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6356 |
The TPMS sensors seem to be EXTREMELY fragile and if the tyre fitter is a ham fisted idiot (like the ones at my supplying dealership) they will more than likely break them when replacing tyres. Discovery 4 HSE
22nd Jan 2010 6:45pm |
