![]() | Home > Technical (L322) > TPMS valves |
| Hunttheshunt Member Since: 02 Oct 2012 Location: Hants Posts: 92
Just received the valves, not quite what I was expecting, no centre piece, do these just screw in, and can Kwik Fit do this?? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882
should look something like this,
| jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563
^^^What Stan said.
Oh...and not sure it's much help but I borrowed my wife's 3 series the other day and when you put her heated rear screen on it totally destroys the radio signal.
re the radio loss, if when you press MAX the heated rear window might be activated , and as the antenna is there there must be a short or bad connection... ... - .- -.
Thanks for the replies, mine do indeed look like Stans picture, but the actual central valve mechanism isn't there, if you look down the barrel so to speak there is just a hole and you can see through to the sensor underneath. Do the valves screw in, why would you take them out.....unless I'm missing something in both senses |
Stan, thanks that makes sense both front and rear heated screens come on, I'll check the contacts on the rear. |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136
The centres just screw in - any tyre place can do that.
as said, the valve cores have been taken out... ... - .- -.
Thanks guys, was worried I'd bought a pair of lemons. They were described as coming off a brand new 2012 RR but obviously had been used just the once, so as I expected. |
| taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121
Same thing happened to me, but rather than risk the new modules not self-programming correctly, I unscrewed the new stems and put them on the original TPMS module. Small torx screw holds it together.
| sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185
I'm changing my mind on TPMS at the moment - they always used to work for me and on the one occassion they were needed did warn me when I had a puncture well before it became a flat.
All seems OK, Kwik Fit got their BIG jack out, new module and valve fitted and seems to sync just fine.
They sync just fine - I swap wheels for winter - it just takes 5-10 mins of driving for them to get recognised. |
