Home > Technical (L322) > timed climate not working |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 |
hi folks, just thought i would mention another annoying fault with my NOV 2004 VOGUE. TD6
27th Nov 2012 7:56pm |
hi contraband, thanks for the reply. i will have a look at your othe reply. with regard to this other problem it is not really something i am too concerned over but it would be nice to know everything is working ok on the car should i ever want to us it.
27th Nov 2012 8:20pm |
hi again contraband, just looked at your other reply and is very interesting but i have a question, which i hope is not a stupid one. you mention that you took the optics out of the blue connector and put them in a straw to keep them straight. am i assuming that the blue connetor now has no wires inside it and is not put back into the unit.?
27th Nov 2012 8:43pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Nokia is the Bluetooth module. There are 2 fibre optic cables go into each unit, an input and an output. If you take the connector out of the Nokia, then take both cables out of the connector (they are held in with a little clip). If you line up the ends perfectly the signal goes out of one cable and into the next, simulating passing through the Nokia. This bypasses the Nokia and if that was the only fault, the system will come back to life!
27th Nov 2012 9:05pm |
hi contraband , ok i think i get what your saying when you put them into the straw, i assume you mean that you put one set in one end of the straw and the other set in the other end of the straw so thay they are pointing at each other is that correct
27th Nov 2012 11:04pm |
Make sure they are touching and no light escapes. Previously..
27th Nov 2012 11:05pm |
i will try it |
27th Nov 2012 11:06pm |
i looked on the wiki link and it has a decription of the denso system and on the pic of the screen, it shows that there is a light in the top right corner of the unit above the buttons? is that supposed to glow as i cant see anything shining out of it and cant remember if it ever did actually light up? |
27th Nov 2012 11:09pm |
hi contraband, my gps ,screen etc etc has just all come back on out the blue on its own, so any ideas or tests you can suggest to find out whats happening with the FBH. as mentioned before i can set the timer etc and that part seems to work and the light goes into its flashing mode to show its in the timing mode but nothing else happens after that. ie when the time is reached for it to start, nothing happens.
8th Dec 2012 10:45pm |
Wow... Question overload.. The FBH is underneath the battery. Can you hear the pump ticking from the back of the car? It supplies fuel to the FBH. There are so many posts about FBH's not working. Lots of people are having problems with theirs just now. Previously..
8th Dec 2012 11:00pm |
well i have heard a ticking noise in the past on several times and wondered it was but i have not tried to listen whilst selecting the heater to start? mainly as nothing happens when i try to start it? thats the problem, not knowing where to start looking. |
8th Dec 2012 11:26pm |
just to let everyone know who may have been watching this post, that the system is now up and running i dont know what happened to get it going again, but as soon as i had fitted the most optic loop to bypass the nokia, is just worked from then on? i dont know if that was simply by chance or as a result of the loop completing the circuit
18th Dec 2012 10:24pm |
