Home > My Range Rover > Newbie to full fat except my waste line
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Nice car. De-chromed and de-sidestepped it'd be lovely (although I'm not mad on huge wheels).
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #154134 28th Nov 2012 5:43pm
mjdronfield
I used to think that about side steps, then I ended up buying one with them on, and realised how much they stopped the seats and side trim taking a battering every time you got in and out.
Mine stay on for that reason only. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #154137 28th Nov 2012 5:48pm
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
My boy is only 11 and he'd do more damage getting in and out if they weren't there!
I checked the transfer box fuse, seems ok! Apparently they have there own ecu that quite commonly fails!!
Post #154141 28th Nov 2012 6:06pm
TheAllSeeingPie
Aaah I suppose with kids they are a necessity. I took mine off because I'm 6'3" and the misses is 5'9" so we don't really need them.
Post #154143 28th Nov 2012 6:16pm
SATVC
Just had a thought is the fuse for the transfer box not supposed to be installed for everyday use? I'm getting the jist that it is only installed for towing??
Post #154494 30th Nov 2012 2:15pm
You are right, "that" fuse is only if being towed (puts box in neutral) there are other fuses however that relate to the gearbox ecu and the shift motor. Check handbook for which ones. Transfer Box ecu is tucked away behind the battery. Search the gallery for my "reveal" howto Wink
Next:
Try the manual calibration procedure
Also would be good to get faults read.
Are you only getting "slow down" / "low range" messages on the dash? "off road height" ? Trans Prog Failsafe ?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  .
Post #154531 30th Nov 2012 3:43pm
nice car Smile All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #154534 30th Nov 2012 3:50pm
SATVC
That's great I'll have a look into this!
Yes I'm only getting SLOW DOWN & SELECT NEUTRAL??? No others
Post #154546 30th Nov 2012 4:33pm
SATVC
I've bought a second hand transfer motor today! Hopefully that should sort that out!
Post #154764 1st Dec 2012 8:44pm
