Home > Technical (L322) > Gearbox about to go? |
hoppy Member Since: 11 Mar 2012 Location: birmingham Posts: 165 |
had a similar problem in the summer....
19th Dec 2012 1:00pm |
andrew-a Member Since: 07 Sep 2011 Location: Wirral Posts: 70 |
19th Dec 2012 1:03pm |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
Sure it's the gearbox? Could be the engine not responding to the throttle - MAF could be on its way out. |
19th Dec 2012 1:04pm |
19th Dec 2012 1:08pm |
Mass Air-Flow sensor - in the induction pipe from the air filter. If they pack up, they don't seem to cause a fault code, but the engine starts running rough - i.e. acceleration can be a bit all or nothing for example. |
19th Dec 2012 1:09pm |
dont know of any garage that does a gearbox fluid change as part of a service free use of "RSW" all comms to anyone nearby |
19th Dec 2012 1:12pm |
that sounds likely - thanks how much are they to replace? |
19th Dec 2012 1:15pm |
http://www.ebay.co.uk/itm/Range-Rover-L322...0841421748
19th Dec 2012 1:17pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
I had similar issues and it was cleared by a single flush of fluid and a filter change on the gearbox. A double flush might change more oil, but it costs a lot more and isn't always necessary. The Megaflush guy wasn't very accommodating, although I'm not convinced by the Megaflush process anyway.
19th Dec 2012 1:56pm |
