Home > Maintenance & Mods (L322) > TD6 - front pad fitment and wear indicator |
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 |
One wear indicator per axle, nearside front and offside rear not sure about the pad sizes though. when i ordered mine i gave my reg and the ones i had were right. Hope that helps. gone fishin' |
22nd Dec 2012 5:12pm |
There are two different pads for your TD6, make sure you order the correct ones |
22nd Dec 2012 6:04pm |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 719 |
Cheers guys
22nd Dec 2012 6:37pm |
Easiest way is to take an old one out, that way you can't get it wrong |
22nd Dec 2012 6:42pm |
Knew you was gonna say that...... |
22nd Dec 2012 6:44pm |
It is the easies foolproof way |
22nd Dec 2012 6:45pm |
Have bit the bullet and put my faith in ECP's 'enter your reg' system and ordered front Pagid pads @£33, plus front wear sensor (just in case) and copper grease and brake cleaner.
26th Dec 2012 3:39pm |
Flexi pipes from LR, metal pipes have the garage make them from Kunifer |
26th Dec 2012 3:43pm |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Actually there is only one pad for the 2002-05 TD6 - there is another pad for the 2006 TD6, tho.
26th Dec 2012 11:31pm |
Coz you were the guy |
26th Dec 2012 11:35pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
I did wonder because I ordered some pads from Duckworths and he didn't ask which ones.
27th Dec 2012 12:03am |
...on the receiving end, yup. Twice. Because I'd forgotten over the life span of a set of pads. Actually, all L322 calipers (both diesel and petrol) are the same from 02-04 and poss into 05 - I'd have to check on the petrol, the TD6 calipers didn't change until 06. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
27th Dec 2012 9:08am |
I had new pads sent to me from Dan and they were the wrong ones |
27th Dec 2012 11:06am |
I guess I just got lucky. |
27th Dec 2012 12:31pm |
