![]() | Home > Technical (L322) > no drive in reverse.... |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Check the wiki for the gear selector cable article. If that doesn't fix it you might be in the Sales Of Goods Act territory with whoever you bought it from. |
bigee Member Since: 23 Nov 2012 Location: wales Posts: 58 ![]() |
Thanks for the reply...just looked at the Wiki,fingers crossed |
Tis done....selector seems a bit slicker? Will see over the next couple of days..Thanks for the heads up |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
Now you have it free with WD 40 give it a good coat of grease to protect and lubricate for the future. |
noted and done.....every other forum where a question is asked re: FF this is the default answer given.....i can see why |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1033 ![]() ![]() |
Which model is your L322?
Phil, its a 2002 4.4 v8......pics to come shortly(when i can stop driving it for long enough to take some |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8778 ![]() ![]() ![]() |
funnily enough it has just occurred to me that i used to have exactly that problem with a E61 BMW, it was like it had to think about engaging reverse, and you could rev it in R to no avail, then it would engage, i wonder if this was a similar related problem.
did you ever get to the bottom of it? |
No, choped it in for the ff. |
..Twas a good move...... |
Losing reverse isn’t that common with the later 5HP24s. I’ve never seen an F-clutch piston seal wear problem (which plagued the early BMW/Jaguar versions) on an L322 :
Fantastic, i will (fingers firmly crossed ) see over the next day or so if it was merely the linkage...if not,then i will have to find a decent indi (forum member??) as my mechanical knowledge is somewhat limited!!
greatw Member Since: 06 Aug 2012 Location: Up North Posts: 21 ![]() ![]() |
I'll watch this one with interest!.
