Home > Technical (L322) > SAT NAV ON GOLF COURSE !!!!! |
Probably the little heard of SANTA V effect, swirling after effect vortexes from 24th .
31st Dec 2012 11:24am |
Probably the little heard of SANTA V effect, swirling after effect electro magnetic vortexes from 24th .
You got a touch of googsy2itus as well then Joe … |
31st Dec 2012 11:28am |
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 |
boys boys settle down and HELP,
31st Dec 2012 1:23pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
try that Sal or a battery reset.. ... - .- -.
31st Dec 2012 1:28pm |
thanky you stan,
31st Dec 2012 1:41pm |
Could be the SAT NAV aerial/receiver had one go on similar Jag unit recently and then SAT NAV only works on dead reckoning. The Jag one was in the tailgate spoiler and got killed by water ingress. Simple replacement fix. |
31st Dec 2012 3:42pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
There should be an option in the menu to reset/recalibrate position - also there is an option there for resetting it after a tyre change. |
31st Dec 2012 4:37pm |
Yes but if it needs recalibrating there will be a reason.... |
31st Dec 2012 5:00pm |
Thank you guys will check it over
31st Dec 2012 9:05pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
My sat nav said I was on a golf course once .... but unfortunately it was right. Serves them right for not letting me turn around in their car park when I got lost ....
1st Jan 2013 1:38am |
1st Jan 2013 10:31am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7631 |
Excellent.
1st Jan 2013 11:40am |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Spewed coffee on my keyboard... Salb, I don't have much experience with the later Satnavs, but if this was a pre-touchscreen I would immediately concur with Gaz - bad GPS antenna (or antenna cable/connector). RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
2nd Jan 2013 11:21am |
