![]() | Home > Technical (L322) > Engine heat drops with fan speed. |
Norway Member Since: 09 Dec 2012 Location: Høvik Posts: 123 ![]() ![]() ![]() |
YO.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35828 ![]() ![]() |
"fullfat rr basterds". |
If say your viscous fan could be sticking on more than it needs. Take it off and see if it improves the problem |
Damn. Now i Only get cold air out the coupe air vent, even when the engines hot. Any clues ? -03V td6
If you mean the central vents in the dashboard are blowing cold air, that is possible. Underneath the vents, right in the middle there is a little wheel with red and blue dots on it. It allows you to separately from the rest blow warm or cold air in. Dial that wheel to red and there should be warm air coming out. MY 2010 5.0 SC Galway green and sand interior!!
LOl, had to read your reply twice as I thought you joked. This goes for the all the vent outlets, front and rear.
Sounds like an airlock to me |
KP is right, could be air in the system, as well. All the more reason to keep an eye on the expansion tank and maybe overfill it a bit while it is bleeding. Driving with the car will also help, try to find some hills so the car rocks left/right, front/back to dislodge the bubbles in the system as much as possible.
Man I felt arrogant when I sow the horizontal air mix wheel under the front fan outlet. It was set to cold. Sorry man, and thx for pointing this out. No air in the system and antifreeze fluid ok. The car just goes cold at higher rpm. Sow Iam back to the enginefan. What are regulating the fan speed? -03V td6 -72 Cadillac Coupe DeVille 7,7liter. |
Glad my tip was of some help |
Let's just explore the viscous fan operation for a moment:
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
How to check a viscous fan Click |
Thanks 47p2, but sod that for a game of soldiers |
When the engine it not running it could be evident when you push it by hand and it gives a lot of resistance.
