![]() | Home > Technical (L322) > Engine heat drops with fan speed. |
| cold_n_wet Member Since: 07 Jan 2013 Location: Norway Posts: 3 |
Have you had your webasto checked to see if is working ? |
| Norway Member Since: 09 Dec 2012 Location: Høvik Posts: 123
No i have not, but The webasto ony accelerate The heating, right? It should not have anything to do With The fan speed, nor Engine rom. -03V td6
| JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833
Or alternatively if you can grab it and stop it with your hand its fine, if you have no fingers left its not!!! One day your life will flash before your eyes......................................make sure yours is worth watching!
| DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425
Back to Joe90's post earlier where he asked is there some turning of the viscous fan. Just returned home and parked up for 10mins, temp gauge slap bang in the middle - no movement. Just started up to move back and temp gauge at 1/4, ok its -7 at the moment, FBH activates. Using the opportunity to check the fansd, i left it in idle, temp still at 1/4, FBH on, peering through the grill 'electric' fans still, but the viscous fan was turning - not with great gusto but all the same turning. Wondering if the turning is normal?. Bit long winded i know but...... |
| jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147
The cable connects to this little wheel using a completely crappy bit of plastic. Mine broke, on the cold setting, of course. Remove the vent piece to see the plastic crap. That made me sad. Jim 2000 NAS HSE 2005 NAS HSE |
It will turn a bit with the engine, it locks more as the motor gets hotter. One day your life will flash before your eyes......................................make sure yours is worth watching!
Thanks Johnny. I had a text exchange with the UK based [Hailsham] Chief Engineer last night. He said the same, some turning with engine in idle. Did the engine off test, fan turns both ways with a little resistance. So it's back to the drawing board. |
Hi,
| Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479
Could the thermostat be stuck open? 56 TDV8 Vogue SE
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Sounds like the thermostat to me too. Cheap place to start |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Take the viscous fan off for a week and see what happens.
HI, The main thermostat was changed, is there a second one.
Is there step by step guide on dismantling the viscose fan. -03V td6
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020
Do NOT run your rangy without the vicious fan.... You will blow your cylinder head gasket or crack your head
| All times are GMT |
