Home > Technical (L322) > Key programming - key lost program
RCusden
Wales
I have to reprogram my keys as they have both lost the remote function. When you say they both have to be done together is that within the same 30 sec time that the bcu is looking for codes or push the buttons on both keys at exactly the same time.
Cheers roger
Post #220209 1st Nov 2013 6:53pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
zetjester wrote:
http://www.autokeytransponder.com/product_details.php?category_id=201&item_id=1577
thanks daveo much appreciated Very Happy
Says in the description 315MHz - American spec, or 433MHz - 315 won't work on a UK car - wrong frequency - I see they do both - but I reckon they've sent you the wrong one.
Post #220325 2nd Nov 2013 1:37pm
MachineHead
Scotland 2009 Range Rover Westminster TDV8 Mariana Black
I realise this is an oldish thread but when I got my FF I had only one key working remote locking and tried this. It worked a treat thanks Thumbs Up
Took me a couple of times but I discovered the easiest way was to hold unlock for the count of 13 then press unlock three times in succession and releasing both. welcomed by the joyful sound of unlock and lock, repeated with second key immediately after and hey presto 2 working keys.
Post #257066 30th Apr 2014 8:21pm
Hammer
Australia 2007 Range Rover Vogue TDV8 Zambezi Silver
Worked for my 2007 vogue tdv8, needed to try a several times before I got I right though.
Post #314249 22nd Feb 2015 8:27am
adigorn
Referring to the easiest way- MachineHead says to hold unlock for 13 sec than press unlock 3 times and release BOTH
I am assuming: hold unlock for 13 sec than press lock 3 times and release both?
Correct me if wrong trying to sync remote to 08my L322 with no luck so far with genuine key
Cheers
Post #557114 9th Jun 2020 10:19pm
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
I got my two keys refurbed by Timpsons for £30 each but only one key can do the wireless remote.
The problem is the new buttons are so hard to keep pressed that the resent procedure keeps failing.
Just something for folks to be mindful of! "Gloria" 2002 L322 Voguish V8 LPG - carcass
"Jessica" 1996 Disco 1 300 TDi Auto
"Harriet" 1994 Disco 1 300 TDi Manual - Gone
"Daisy" 1992 Disco 1 200 TDi Manual - Gone
Post #558411 20th Jun 2020 8:36pm
BigJon
Australia 2007 Range Rover Vogue TDV8 Chawton White
Brilliant, worked perfectly for my new key after replacing the aerial booster in the upper tailgate. Waiting for the second new key to arrive, then it will be good to have two fully operational keys again.
Post #595917 31st May 2021 7:10am
CongoBoy
South Africa 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
This worked for me after six months of trying.
I had to get two keys working after I bought my FFRR S/C.
The first step is to make sure they are programmed/reprogrammed to the key.
Mine worked already, as I had to get in and out with the key, and start it with the same.
To sync the remote takes a lot of perseverance and patience!
My first problem was my battery (the vehicle, not the keys!!).
This was causing a lot of other faults as well.
Once I changed this, I managed to sync the remotes.
But it takes several (lots!) of attempts but it's so satisfying when those locks click up and down!! 2005 FFRR SC Java Black with Overfinch Exhaust (UK)
2008 D3 HSE Stornoway Grey (UK)
2008 D3 HSE Izmir Blue (ZA/Zimbabwe)
1995 D1 300 Tdi (Zimbabwe)
Post #596006 31st May 2021 7:40pm
hbthepilot
Austria 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi every one,
just received a new key from Land Rover - synced it and it opens the doors just fine but it won't turn the ignition.
Any help? Bow down
BR
Post #598553 24th Jun 2021 9:23am
CongoBoy
This will be the transponder.
I am not sure if they now need to be programmed to the car using an IITD tool? 2005 FFRR SC Java Black with Overfinch Exhaust (UK)
Post #598562 24th Jun 2021 10:02am
