Home > Maintenance & Mods (L322) > Boot lettering measurements.
Googsy
There has been a few posting recently regarding Range Rover Lettering. I recently changed my lettering with cheaper non genuine lettering and as a result I did not position the boot lettering correctly. I now have some genuine lettering i would like to replace it with .Could someone to please advise the following measurements I'm sure this will help other members in the future too.
Distance from top of silver strip to bottom of lettering
Distance between lettering as in The E and R
Finally the measurements from the side of the boot lid lip on both sides to the R in Range and the R in Rover.
Many thanks for your help. I understand the bonnet lettering has a slight curve so that may be more difficult.
Stan might be useful for the Wiki Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #181737 7th Apr 2013 7:03pm
Bantam
2007 Range Rover Vogue SE TDV8 Java Black
Boot Lettering Measurements
Hi There,
Just measured up here's the measurements on mine (2007 TDV8)
Top of Boot Strip to bottom of lettering: 29mm
From LHS to 1st R: 280mm
From LHS to end of E of Range: 645mm
Gap between end of E (range) and beginning of 1st R (rover): 90mm
From RHS to beginning of 1st R of Rover: 649mm
From RHS to end of last R of Rover: 270mm
Spacing between individual letters is tricky to measure because of the shapes - i guess they are put on using the center line of each letter and equal centers between 1st and last letter of each word.
Hope that helps
Andy
Post #181741 7th Apr 2013 7:43pm
Googsy
Thumbs Up Bow down Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #181743 7th Apr 2013 7:54pm
Well on mine …… This is the Rear Letters
Distance from top of silver strip above number plate to bottom of lettering …. 25mm
Distance between lettering as in The E and R ….. 90mm
Distance between the Side Lip of the tailgate to the first R Drivers side … 275mm
Distance between the Side Lip of the tailgate to the last R Passenger side … 275mm
The Front Letters
Distance between the crease line on the Bonnet to the First R drivers side .. 525mm
Distance between the crease line on the Bonnet to the last R passenger side …. 525mm
Distance between the Lip of the Front Bonnet to the bottom of the E and R ..30mm
Distance between the Front E and R … 90mm
This being the Crease Line from the front Bonnet just above the orange Marker Light
Post #181745 7th Apr 2013 7:55pm
Googsy
Interesting would be good to get 3rd measurements to confirm cheers Mick Thumbs Up
Looks like you might have had lettering replaced at some point Bantam given differences on both sides as Micks seem exact both sides Question Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #181748 7th Apr 2013 8:02pm
On mine
Left tailgate to first R 275mm
Gap between E and R 90mm
Right Tailgate to last R 280mm
(measured from the upper part of the R, a bit less if you measure from the bottom of the angled leg) .
Post #181761 7th Apr 2013 9:37pm
supershuttle
There's a lot of good info on here regarding spacing etc but the lettering does extend past the boot strip and so i measured 43mm to the bottom of the first and last "R's" with my flexitape hooked under the bottom edge of the upper tailgate. I would suggest a straight line (drawn with a white board marker or something else that rubs off easily) between the two points will give you a decent base line.
I also noticed some bubbling of the paint on the edge of the upper tailgate when I took these measurements - Censored Geoff
Post #181966 9th Apr 2013 10:18am
supershuttle
For the bonnet - it's easier just to find the centre of the grill and then mark the centre of the bonnet accordingly and the lettering is 45mm each side of that line - 90mm apart as stated elsewhere. Geoff
Post #181968 9th Apr 2013 10:21am
