![]() | Home > Technical (L322) > How do you clean mud off the underside of the car? |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Well I went off-roading this weekend and had a great time. Unfortunately the FFRR is now caked in mud underneath and around the brakes and suspension. I tried a gentle pressure wash to get the worst off, but unfortunately the brakes are clogged and dragging a bit too.
Like this |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988 ![]() ![]() ![]() |
Garden sprinkler works a treat. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35867 ![]() ![]() |
most car washes do an underside wash...
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
^ Worthless in my opinion, the one i have seen wont touch any real mud. At best they help rinse the salt off a little. 5 mins with a pressure washer is mile better. |
We didn't have any clean water to get rid of the muck. Only streams filled with clay and occasionally cow dung. Was a hell of a day though and can't wait to do it again. |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
One year I went to collect my son from T in the Park and the mud was so bad it coated everything underneath and it set like a cement like substance. It took hours with a pressure washer to shift it, hours. Doms picture is the way to do it, let it soak, then blast it off. Previously..
£10 on a garden sprinkler and if its rock hard leave to soak in a little. Use the mist setting to soak and then the stronger one to wash off.
You were there mate if you recall.....Salisbury 2011 |
i know |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 746 ![]() ![]() |
If you have a Karcher ...
that looks good |
£65 off fleabay...
'Cos that's Redneck engineering, that's why KP ![]() |
