Home > In Car Electronics (L322) > AV In Front Screen
Rexyboy
Australia 2008 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
AV In Front Screen
Hi,
I have just purchased a 2008 RR Vogue Supercharged and looking for some advice on AV inputs. I want to have an AV input that will display on the front screen. From what I can see the Aux inputs in the back seat will only play on the RSE system. I have searched through the forum (and googled) but cant find an answer. Is there a standard or aftermarket way of getting the video on the head unit?
BTW I am aware of the video in motion restriction.
Thanks.
Post #186779 6th May 2013 9:00am
Tuts
There are a/v leads that add an aux to the tv tuner for the BMW based ranges (search eBay for range rover aux) can't see why they can't make the same leads for the denso based tv tuners (can't see any on eBay though?) might be worth contacting the sellers of the earlier models leads? 2003 Vogue 4.4 V8 Java Black
Post #186946 6th May 2013 11:32pm
http://www.disco4.com/shop/index.php?act=v...oductId=34 ... - .- -.
Post #186964 7th May 2013 8:25am
stan wrote:
http://www.disco4.com/shop/index.php?act=viewProd&productId=34
Stan, the FF already has 3 fakra leads connected... Crying or Very sad Thumbs Up
Post #186986 7th May 2013 9:28am
Re: AV In Front Screen
Rexyboy wrote:
Hi,
Thanks.
Speak to these guys?
http://www.toysinyourcar.com/acatalog/AV_I...TH_TV.html
Post #186987 7th May 2013 9:30am
not going to argue with an expert but is not one of those sockets free? [3 sockets on top right]
Post #186989 7th May 2013 9:33am
No no stan... They are all taken... Crying or Very sad
Post #186991 7th May 2013 9:36am
so would that be a tv tuner, sat nav and ? ... - .- -.
Post #186992 7th May 2013 9:45am
Reverse camera Rolling Eyes Whistle Yawn
Post #186994 7th May 2013 9:53am
I was using my RSE this weekend and found the following:
You can have one rear screen watching the DVD that's playing
You can have the other screen watching something from the AV inputs in the rear
You can watch TV, DVD or anything else in the front, but you can't watch the AV inputs, you can only listen to the AUX input.
Another top tip if you find the infra red headphone reception is poor on one or both sides...read this.
http://www.fullfatrr.com/forum/topic14297.html Discovery 4 HSE
1998 90 TUL FFR Hard Top XD Wolf
1993 90 Tdi
*Gone: L405 4.4 VSE, L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB
Post #187005 7th May 2013 10:37am
Martin
Site Admin
The 3 FAKRA composite connectors are used for:
  • reverse cam (brown)
  • venture cam (tan)
  • RSE/DVD/TV (green)
The sat nav feed is a GVIF connection to the pale blue rectangular connector underneath them.
Post #187006 7th May 2013 10:50am
so its possible to utilise the venture cam input if you dont use it or the rse input if you havnt got it.. ... - .- -.
Post #187007 7th May 2013 10:59am
You can see what's configured through the "753" hack diagnostic screens, oddly I think mine says that RSE isn't fitted, even though it is! Discovery 4 HSE
1993 90 Tdi
Post #187010 7th May 2013 11:06am
Rexyboy
So far the only interface I have found is this one:
http://www.nav.tv/products/audio-visual-in...09?car=132
from NavTV but at Ł500 it's enough to make your eyes water. I would love to find a more reasonable option if anyone has some thoughts?
Thanks.
Post #187017 7th May 2013 11:58am
i dont think there is anything much cheaper..its the MOST system that makes it expensive.. ... - .- -.
Post #187019 7th May 2013 12:00pm
