![]() | Home > Technical (L322) > Slight problem |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Curious... If you have tv/video on the front screen, does it switch off when you let the handbrake off and drive? Previously..
Pull out the bottle holder in the centre and look down at the handbrake and see if the wire has broken off as usual... |
Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212 ![]() ![]() |
I have tv but I don't think it works to be honest, not sure what frequency it is?
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 ![]() ![]() ![]() |
It wouldn't matter on mine, the bloody hand brake doesn't even work on mine... |
Ha, mine doesn't to great effect, I found a plug near the hand brake which is a female type red, so in guessing that's that! Though my park, I can't really get beside the bottle holder easily, I can see down there but can't see any loose wires? |
I've just re read your post ill try that cheers |
Any ideas why my park light isn't on? When it's in park? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35853 ![]() ![]() |
bad connection or bulb gone.. ... - .- -.
It comes on, on start up then goes out with all the others, it's like it's turned off or something, like the seat belt light that doesn't stay on either if I leave the belt off?!! |
i wouldnt worry about it to much if the handbrake works.. ... - .- -.
Seat belt chime/light only stays on after 07 facelift... PND lights inop may mean an issue with the gearbox switch... |
Ok thanks, any pointers as to its whereabouts? Cheers |
