Home > Technical (L322) > rear wiper arm question
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi All
I have just purchased a genuine replacement rear wiper arm from land rover part LR012046 and i have just come to fit it and it doesn't have any splines in the hole where as the old arm has splines and so does the motor. Can anyone advise if this is correct or i have a faulty part?
Matt
Post #195523 21st Jun 2013 6:32pm
seems to be the correct part number , does the spline bit in the old arm come out and then fit into the new arm.. ... - .- -.
Post #195525 21st Jun 2013 6:35pm
mattstevenson2005
no its not a removable part its cast as part of the old arm
Matt
Post #195526 21st Jun 2013 6:36pm
i've googled that part number and loads have it specified for the l322, maybe ducky Dan could enlighten the situation but he's probably off till monday.. ... - .- -.
Post #195527 21st Jun 2013 6:38pm
scorpiont10
United Kingdom 2006 Range Rover Vogue SE 4.4 V8 Java Black
There were no splines on mine when I replaced it. The arm is cast aluminium, and I figured that the splines on the shaft imprinted onto the old arm. I haven't had any problems so far Thumbs Up
Post #195549 21st Jun 2013 9:03pm
I don't think they have splines. I think the taper and the nut create the splines in the wiper arm. That way if anything stops the motor the sacaficial bit is the wiper arm. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #195555 21st Jun 2013 9:21pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
+1 Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #195595 22nd Jun 2013 9:44am
Its an imprint made after its fitted... Thumbs Up
Post #195602 22nd Jun 2013 10:44am
