![]() | Home > Technical (L322) > Low Coolant Warning / Reduced Engine Power Warning |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Somewhat worryingly since I collected my S/C last week from having new lights fitted, I'm now getting a low coolant alarm when the S/C is being driven quickly / at high rpm / Sport Mode.
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 ![]() ![]() ![]() |
May be a red herring but check the fan is rotating the right direction? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
possibly something was 'knocked' when the lights were fitted...i'd have a good look and see if its anything obvious around the headlight areas.. ... - .- -.
Reduced engine performance warning normally means overheating of engine or gearbox.... |
If not a passing glitch methinks 'a rocket' might be heading somewhere soon! |
Just behind your driver side headlight is the coolant tank. In the bottom of the tank is a sensor that senses density/level. Now assuming that they removed the tank for the work, they may have re-filled it with water iso coolant (bad mistake) and that screws up the sensor so it thinks the level is too low.
Thanks all!
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
There's a VIN range for the badly wired ones, so thats an easy check. The coolant level can happen if you sling round too many corners for a while, goes away when th coolant returns. |
Just driven home from deepest Devon via Bath (150 miles) and I had the low coolant warning ONLY when the engine was thoroughly warmed up and ONLY on reasonably hard acceleration and never on bends.
My guess is on water to top up the coolant in the tank. Suggest to drain the tank and fill it with coolant to see if that helps. Otherwise replace the sensor, easy job with the tank out (and that is also easy). Sensor is quite cheap I remember. Don't forget to take the little rubber cap on top of the probe of though, it protects the little metal sensor tip. MY 2010 5.0 SC Galway green and sand interior!!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
PM returned |
