Home > Technical (L322) > Titanium Trim Piece replacement
funnyguy1
United States
Has anyone ever replaced the plastic titanium trim piece that runs between the fog lights under the front bumper on a 2010-2012 SC? Have ordered a new one for mine but can't see the snaps to remove the old one. Thx! Mike
Post #207218 1st Sep 2013 6:09pm
As far as I know it's either some simple clips or adhesive. When your new one arrives you'll be able to see how it goes on, not rocket science I bet. Discovery 4 HSE
Post #207224 1st Sep 2013 6:33pm
AMD
I think Mick will tell you differently! Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #207244 1st Sep 2013 7:40pm
paneldamage
There are about 12 little 'tongues' that slot through the backing bumper, these have a tooth type end that holds the trim on, difficult to remove from the front, as Mick knows, but straightforward if you take the bumper off and release the tongues one by one, starting at one end.
Post #207263 1st Sep 2013 8:56pm
funnyguy1
United States
Thank you! I don't think I will be removing the bumper but can you see then from underneath the car? Mike
Post #207269 1st Sep 2013 9:25pm
verydisco
I took my titanium silver one to replace it with a black one while the bumper was off.
Then this is easy(ish), pull tabs one by one.
I think you only change to do itin sity is to have the Rangie on a lift. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #207273 1st Sep 2013 9:48pm
Removing the front bumper in that case is not very hard, I did it on my last one, its actually held on by about 10 screws. Discovery 4 HSE
Post #207278 1st Sep 2013 10:02pm
paneldamage
Hi , sorry been away from laptop for a few days, I am pretty sure you can't get to the back of he trim piece...if
you don't remove the bumper, try easing it off slowly tab by tab.
Post #207801 3rd Sep 2013 10:55pm
Watch a video on taking Bumper Off really quite easy and ten minutes.
Post #207847 4th Sep 2013 7:58am
Removing the strip is a PITA job with the bumper on...
Post #207871 4th Sep 2013 9:05am
funnyguy1
United States
Hi, Where can i find a video showing how to remove the front bumper? I googled it and nothing came up. Thx! Mike
Post #207997 4th Sep 2013 6:06pm
I assumed there would be a video like the one for the rear bumper.
Its held on by screws only Craig may be able to tell you exact location of each screw.... Whistle
Post #207999 4th Sep 2013 6:26pm
If you have a friend to help you makes it easier , lying underneath the front of the car you will see where the rim of the splitter bar starts ……
So get two thin tipped flat headed screwdrivers … start at one end first when you prise out the first teeth (clip) press the splitter bar up at the same time whilst getting your friend to insert his screwdriver next to yours he keeps the pressure on the splitter bar open … you then move onto the next tooth (clip) and do the same prise the second one open by then the splitter bar will have made a bigger and easier gap for the two of you to work along tooth by tooth to prise off …..
Mind the splitter bar might break at some point in case you are hoping to keep it ….
PITA to do Thumbs Up Thumbs Up
Post #208005 4th Sep 2013 6:36pm
I think spraying the bar in BMW Titanium Silver would be easier! Whistle
Post #208007 4th Sep 2013 6:42pm
PITA masking off area around it tho … if you want a pro look
Post #208008 4th Sep 2013 6:45pm
