Home > Maintenance & Mods (L322) > Td6 small oil cooler gasket.
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
My Td6 has a small oil cooler next to the oil filter on the side of the engine.
This looks like it has a small leak from the gasket that's between it and the engine.
Part No. LVH 000020
68SN A0652313 MELOR. ON THE PACKAGING.
Is this an easy job to change it out and has anyone done one what will i need to do the job ie tools , oil , coolant etc.
Just don't want to start the job and find i am missing something.
Thanks Guys.
I THINK IT MIGHT BE THE GEARBOX COOLER,
Post #216527 15th Oct 2013 9:43am
Have you cleaned the area around the leak and confirmed this is where the leak is seeping from?
Post #216612 15th Oct 2013 3:38pm
steve9bug
looks to be from that area but will get the de greaser on and clean it off and try and pin point the leak
Post #216643 15th Oct 2013 4:49pm
Mine was leaking in that area, turned out to be a loose fuel pipe
Post #216664 15th Oct 2013 5:59pm
Mustard
Having just had mine changed after a total failure I have these 2 pics of it unboxed and clean Laughing
My friend did the job for me and he did have a bit of an issue with 1 of the bolts underneath it and he found it much easier to take the cooler off with the oil filter housing still attached, do the swap over and then re attach the lot. For us it was a messy job but I think thats because of a different issue Whistle
Post #216771 15th Oct 2013 9:49pm
greasemonkey1
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Re: Td6 small oil cooler gasket.
Part No. LVH 000020
Thanks Guys.
hi steve
you sure you're not talking about the diesel cooler,has a big black plastic air inlet going onto it...it sits on the right hand side of the engine near the top mount near the diesel filter...if you can get some pics up..
Post #216812 16th Oct 2013 7:10am
steve9bug
No mat same as cooler pic that's been cleaned
Post #216817 16th Oct 2013 7:58am
